VRRP Track Prefix List
akoukis
I'm trying to configure VRRP on the service VPN using the Track Prefix List. Doesn't anyone know where I can define this Prefix List? I tried on Policy List-> Prefix but I take an error when I try to push the configuration.
illegal reference /vmanage-cfs:templates/template{vip_internal_temp_device_C8500L-XXXXXX 6bd13125-fb5a-4c8d-b228-77e9908669ab}/vpn/vpn-instance{100}/interface{GigabitEthernet0/0/1}/vrrp{110}/track-prefix-list
Thank you
Anestis
Adrian Jimenez
Hi Akoukis,
This was really an annoying one to replicated on lab but here's how I came around it . You'll have to create a dummy policy that programs your "prefix-list" into config and then reconfigure your VRRP to call the "track-prefix-list" if that makes sense. You can always get away with a CLI Add-On Template if you're looking for something simpler.
1) Creating a dummy policy with prefix-list:
- Policies > Localized Policy > Add Policy > Prefix > New Prefix List > “Create your prefix-list” > Next till “Configure Route Policy”
- Here you want to do Add Route Policy > Add Sequence Type > Add Sequence Rule and then add “Address” as your match condition and select your prefix list.
- Then just save “Save Match and Actions”. Then Save Policy.
- Once with your dummy policy created, go to Device > Templates > Device > Edit > Additional Templates > Policy.
- Select yours and update the template.
- Once pushed and the prefix list configured on the device you will be able to configure the “track-list-prefix” option.
2) For a CLI Add-on template option, just do this and then re push VRRP config:
policy
lists
prefix-list VRRP_PREFIX_LIST
ip-prefix 192.168.100.0/24
Those were the 2 options I used to make it work on my lab, let me know if any of that makes sense!
AJ
6 Replies 6
manuelosorio
Hello @akoukis
Here are the steps to configure.  You must pending the version of the vManager that it refers. Try and let me know.
https://www.cisco.com/c/en/us/td/docs/routers/sdwan/configuration/system-interface/vedge-20-x/systems-interfaces-book/m-vrrp-tracking.html
Hi Manuel, thank you also for the help and the effort you put to answer my question, but Adrian suggestion was what I was looking for.
Best Regards
Adrian Jimenez
Hi Akoukis,
policy
lists
AJ
Thank you Adrian for the help, I was trying to do it from the Centralized Policy and not from Localized Policy.
Thanks again point me right direction.
Best Regards
Hi Adrian,
Did you test it on vEdge only or on cEdge as well?
I do not see CLI syntax option for VRRP prefix-list tracking on cEdge so curious if it is officially supported on cEdge even I see that option in feature template.
Ivan
