Showing results forĀ
Search instead forĀ
Did you mean:Ā
vEdges unreachable issue
abdalftahZak
hello all
i have a problem with my vEdges .. i registed all vEdges on my vManager and all vEdges got uniqe Serial number and i cant ping all controllers from vEdges
but when i open the main dashboard on vManage website i see that all vEges are unreachable
i I checked the org name and the timezone and its same in all controllers and vedges
i tried the "show control connections" command in vedges and i didnt see anything , also in vBound
but in vmanager
0 vsmart dtls 10.1.1.2 10.1.1.2 1 1 195.1.1.3 12346 195.1.1.3
12346 ORAKATE default up 0:00:26:03
0 vbond dtls 100.1.1.1 100.1.1.1 0 0 195.1.1.2 12346 195.1.1.2
1 vbond dtls 0.0.0.0 - 0 0 195.1.1.2 12346 195.1.1.2
12346 ORAKATE default up 0:00:26:02
2 vbond dtls 0.0.0.0 - 0 0 195.1.1.2 12346 195.1.1.2
3 vbond dtls 0.0.0.0 - 0 0 195.1.1.2 12346 195.1.1.2
12346 ORAKATE default up 0:00:26:05
so i think there is no problem in the connectivty between the controllers
i cheaked if the certificate are installed or not and its installed
vEdgeS4# show control local-properties
personality vedge
sp-organization-name ORAKATE
root-ca-chain-status Installed
certificate-status Installed
certificate-validity Valid
certificate-not-valid-before Mar 18 16:38:47 2025 GMT
certificate-not-valid-after Mar 16 16:38:47 2035 GMT
dns-name 195.1.1.2
site-id 4
domain-id 1
protocol dtls
tls-port 0
system-ip 10.1.1.105
chassis-num/unique-id 47aed029-9176-3b8d-6bbb-5a2dd92fd659
serial-num 10B13463
subject-serial-num N/A
abdalftahZak
solved
i didnt use the same vbond ip in my smart account
