vSmart - cEdge Control connections
RS19
Level 4
Level 4
If a cEdge has 2 internet connections & there are 2 vSmart & in this scenario how many control connections will be establisehed.
Will it be 4 or 2 ? 4 means each internet link IP wll form connection with both the vSmart, so there should be 4.
Is my understanding right ?
by default each interface is allowed to have 2 control connections (means connections to vSmart).
You have 2 interfaces and 2 vsmarts, with default settings result is 2*2=4 control connections > this can be verified by show sdwan control connections | include vsmart
Additional info: Keep in mind that, OMP session is only one between router and vsmart. So, you have 1 OMP with vsmart1 and another OMP with vsmart2. OMP sessions will be 2, not 4 (this is also with default setting, max-omp-sessions) > this can be verified by show sdwan omp peers
https://www.cisco.com/c/en/us/td/docs/solutions/CVD/SDWAN/cisco-sdwan-design-guide.html#SDWANController
HTH,
The edge try connect to any vsmart recieve it ip from vbond by using it wan interface.
You have two wan and two vsmart the control connection is 4.
MHM
In 1 of my cEdge which has 2 transport links  (2 vSmart), it has only 3 control connections.
Transport link - 1 : Control connections with 2 vSmart
Trasnport link - 2 : Control connection wiith 1 vSmart
Ideally it should be 4, but only 3. Is this normal ?
As I said before, by default it should be 4.
If you have 3, then do troubleshooting beginning from show sdwan control connection-history | inc [problematic_vsmart_systemIP] to find errors related that vsmart. Output should be from vedge router
HTH,
