show sdwan control connections
RS19
Level 4
Level 4
For the below commad in cEge, in normal scenario it should show only vSmart and vMange.
Plse claify if myunderstandng is correct ? Does vBond will be visible in the output ?
6 Replies 6
RS19
Level 4
Level 4
My understanding is that only vSmart and vManage should be visible. Not sure why vBond is visible.
This means some problem, any idea what could be the problem ?
The edge connect to vbond for short time to get list of other controller
Then it connects is remove and you must see it in history only after that
MHM
RS19
Level 4
Level 4
I already replied in another topic. Connection to vbond from vedge point of view is temporary - transient.
WAN Edge devices onboard in a similar manner but drop the transient SD-WAN Validator connection and maintain DTLS/TLS connections with the SD-WAN Manager and Controllers.
https://www.cisco.com/c/en/us/td/docs/solutions/CVD/SDWAN/cisco-sdwan-design-guide.html#ControlConnections
So, it is normal that you have only vsmart and vmanage in show sdwan control-connection output
HTH,
But in my environment, I am not able to see vManage but I am able to see both the vBond. Not sure what is the cause of this ?
balaji.bandi
what version of code running.
Once cedge onboarded correctly yes you see only those 2. Initially you see vbond but, once all sync done, you see vManage and vsMart only.
BB
