What are the parameters: VS/VM in Cisco SD-WAN?
Neuling94
Hi!
Who can explain me what is the meaning of column of "VS/VM" in cisco SD-WAN when one performs command "show sdwan control local-properties" and look at the table with tunnel interfaces.
Screenshot is attaced
Any ideas?
Adrian Jimenez
Hey Neuling94,
That just means how many control connections are active to vSmarts (VS) and vManages (VM) in that specific TLOC/interface. If you do a show control-connections, you'll see the number of entries will match with the VS/VM counters. For instance, based on the image attached your show control-connections output won't have any entry for public-internet (Lo3). It will have one entry on 'mpls' for both vManage and vSmart. And it will have 1 entry for vSmart on private1.
Hope that explains it!
AJ
Adrian Jimenez
Hey Neuling94,
AJ
