Use cEdge as Gateway between MPLS and public internet
garrettc134
Is it possible for the following to work? Basically I'd like to see if its possible to use a cEdge as an internet gateway for the underlay.
Topology
Internet---DMZ---cEdge-----MPLS network ----- multiple vEdges
Ideally, the internet facing cEdge interface should be in a service VPN and be used to get production VPN traffic along with underlay MPLS traffic to the DMZ.
For now, my only idea is to leak the default from the service VPN into VPN0 and advertise the default on the MPLS network but it isn't working. Any idea on how to make this work or alternate suggestions?
What version of CSR100V are you using? I think is a version issue. I solved it by using the supported version 16.12:
 https://www.cisco.com/c/en/us/td/docs/routers/sdwan/release/notes/xe-16-12/ios-xe-sd-wan-re-notes-16-12.html#id_117628 )
Best regards,
garrettc134
Feel like I'm close. To making this work. Any advice?
I went down the path of using a loopback for the connections and binding it to a physical interface using the below config but I get the following error with the below config.
interface GigabitEthernet1
   no shutdown
   ip address dhcp  i
interface Loopback0
   ip address 192.168.0.1 255.255.255.255
interface Tunnel0
   no shutdown
   ip unnumbered Loopback0
   tunnel source Loopback0
   tunnel mode sdwan
sdwan
   interface Loopback0
    tunnel-interface
     encapsulation ipsec weight 1
     bind GigabitEthernet1
tunnel-interface bind': The bind interface GigabitEthernet1 must be a valid physical interface
Best regards,
