04-23-2019 12:24 PM
Hi All,
Is Viptela SD-WAN a full multi-tenant SD_WAN solution?
As I found vManage has multi-tenancy features. Does vBond and vSmart support multi tenancy?
04-24-2019 11:19 AM
vManage and vBond support multi-tenancy. Need dedicated vSmart cluster for each tenant.
05-06-2019 12:25 PM
On paper, yes, the solution is multi-tenant. The vbond is the only part which can't be multi-tenant but the vmanage can be installed as multi-tenant. Physically there will be one single instance of vmanage (or a cluster) but it will have multi-tenant capability. Each tenant will have its own dedicated vsmart controllers.
In practice, the whole thing is not really ready for production.
