Alin Iorguta
Introduction
This document describes how to configure a site-to-site (LAN-to-LAN) IPSec IKE Version 1 (IKEv1) tunnels using Virtual Tunnel Interface (VTI) between two Cisco ASA. ASA VPN module was enhanced with this logical interface in version 9.7(1) and is used to create a VPN tunnel to a peer, supports route based VPN using profiles attached to VTI interfaces. More details can be found on Release Notes for ASA software 9.7(1).
Objective
Traffic between HQ and DR should pass across primary IPSec tunnel and in the case that primary link fail should failover to the backup tunnel.
Components Used
  • Cisco ASA version 9.7(1);
  • Cisco 1941 Series Integrated Services Router (ISR) that runs Cisco IOS Version 15.4(3)M2, used to simulate ISP A and B.
Configuration
Network Diagram
The information in this document uses network setup as bellow:Diag_1.JPG
Configuration Steps
HQ ASA Configuration
First, we are adding IPSec Phase 1 and 2 configuration:
crypto ikev1 enable primary
crypto ikev1 enable backup
crypto ikev1 policy 10
authentication pre-share
encryption aes
hash sha
group 2
lifetime 86400
crypto ipsec ikev1 transform-set SET1 esp-aes esp-sha-hmac
crypto ipsec profile PROFILE1
set ikev1 transform-set SET1
set pfs group2
tunnel-group 20.20.20.1 type ipsec-l2l
tunnel-group 20.20.20.1 ipsec-attributes
ikev1 pre-shared-key cisco123
tunnel-group 40.40.40.1 type ipsec-l2l
tunnel-group 40.40.40.1 ipsec-attributes
for VTI interfaces configuration we are using a new feature introduced in version 9.7(1), 31-bit Subnet Mask (“For routed interfaces, you can configure an IP address on a 31-bit subnet for point-to-point connections.”, more information on Release Notes):
interface Tunnel10
description PRIMARY_VTI
nameif primary_vti
ip address 10.0.0.1 255.255.255.254
tunnel source interface primary
tunnel destination 20.20.20.1
tunnel mode ipsec ipv4
tunnel protection ipsec profile PROFILE1
interface Tunnel20
description BACKUP_VTI
nameif backup_vti
ip address 10.0.0.3 255.255.255.254
tunnel source interface backup
tunnel destination 40.40.40.1
to check connectivity to primary interface of our peer we use IP SLA and a track object:
sla monitor 1
type echo protocol ipIcmpEcho 20.20.20.1 interface primary
sla monitor schedule 1 life forever start-time now
track 1 rtr 1 reachability
then, add routes to destination networks/addresses:
route primary_vti 172.16.10.0 255.255.255.0 10.0.0.2 1 track 1
route backup_vti 172.16.10.0 255.255.255.0 10.0.0.4 5
route primary 20.20.20.1 255.255.255.255 10.10.10.2 1
route backup 40.40.40.1 255.255.255.255 30.30.30.2 1
DR ASA Configuration
For DR ASA configuration is similar to HQ ASA, only ip addresses are changed:
encryption aes
hash sha
group 2
lifetime 86400
set pfs group2
tunnel-group 10.10.10.1 type ipsec-l2l
tunnel-group 10.10.10.1 ipsec-attributes
isakmp keepalive threshold 10 retry 10
tunnel-group 30.30.30.1 type ipsec-l2l
tunnel-group 30.30.30.1 ipsec-attributes
interface Tunnel10
nameif primary_vti
ip address 10.0.0.2 255.255.255.254
tunnel destination 10.10.10.1
interface Tunnel20
nameif backup_vti
ip address 10.0.0.4 255.255.255.254
tunnel destination 30.30.30.1
sla monitor 1
type echo protocol ipIcmpEcho 10.10.10.1 interface primary
route primary_vti 192.168.123.0 255.255.255.0 10.0.0.1 1 track 1
route backup_vti 192.168.123.0 255.255.255.0 10.0.0.3 5
route primary 10.10.10.1 255.255.255.255 20.20.20.2 1
route backup 30.30.30.1 255.255.255.255 40.40.40.2 1
Verifying the results
State of IKEv1 Phase 1 and Phase 2 can be checked with following commands:
HQ-ASA# show crypto ikev1 sa
IKEv1 SAs:
Active SA: 2
Rekey SA: 0 (A tunnel will report 1 Active and 1 Rekey SA during rekey)
Total IKE SA: 2
1 IKE Peer: 40.40.40.1
Type : L2L Role : responder
Rekey : no State : MM_ACTIVE
2 IKE Peer: 20.20.20.1
HQ-ASA# show crypto ipsec sa
interface: primary_vti
Crypto map tag: __vti-crypto-map-5-0-10, seq num: 65280, local addr: 10.10.10.1
access-list __vti-def-acl-0 extended permit ip any any
local ident (addr/mask/prot/port): (0.0.0.0/0.0.0.0/0/0)
remote ident (addr/mask/prot/port): (0.0.0.0/0.0.0.0/0/0)
current_peer: 20.20.20.1
#pkts encaps: 246, #pkts encrypt: 246, #pkts digest: 246
#pkts decaps: 246, #pkts decrypt: 247, #pkts verify: 247
#pkts compressed: 0, #pkts decompressed: 0
#pkts not compressed: 246, #pkts comp failed: 0, #pkts decomp failed: 0
#pre-frag successes: 0, #pre-frag failures: 0, #fragments created: 0
#PMTUs sent: 0, #PMTUs rcvd: 0, #decapsulated frgs needing reassembly: 0
#TFC rcvd: 0, #TFC sent: 0
#Valid ICMP Errors rcvd: 0, #Invalid ICMP Errors rcvd: 0
#send errors: 0, #recv errors: 0
local crypto endpt.: 10.10.10.1/0, remote crypto endpt.: 20.20.20.1/0
path mtu 1500, ipsec overhead 74(44), media mtu 1500
PMTU time remaining (sec): 0, DF policy: copy-df
ICMP error validation: disabled, TFC packets: disabled
current outbound spi: E93C8DB9
current inbound spi : 00AC6E39
inbound esp sas:
spi: 0x00AC6E39 (11300409)
transform: esp-aes esp-sha-hmac no compression
in use settings ={L2L, Tunnel, PFS Group 2, IKEv1, VTI, }
slot: 0, conn_id: 86016, crypto-map: __vti-crypto-map-5-0-10
sa timing: remaining key lifetime (kB/sec): (3914979/28492)
IV size: 16 bytes
replay detection support: Y
Anti replay bitmap:
0xFFFFFFFF 0xFFFFFFFF
outbound esp sas:
spi: 0xE93C8DB9 (3913059769)
sa timing: remaining key lifetime (kB/sec): (3914979/28491)
IV size: 16 bytes
Anti replay bitmap:
0x00000000 0x00000001
interface: backup_vti
Crypto map tag: __vti-crypto-map-6-0-20, seq num: 65280, local addr: 30.30.30.1
current_peer: 40.40.40.1
#pkts encaps: 0, #pkts encrypt: 0, #pkts digest: 0
#pkts decaps: 0, #pkts decrypt: 0, #pkts verify: 0
#pkts not compressed: 0, #pkts comp failed: 0, #pkts decomp failed: 0
local crypto endpt.: 30.30.30.1/0, remote crypto endpt.: 40.40.40.1/0
current outbound spi: 446005A9
current inbound spi : 8BB0984A
inbound esp sas:
spi: 0x8BB0984A (2343606346)
slot: 0, conn_id: 77824, crypto-map: __vti-crypto-map-6-0-20
sa timing: remaining key lifetime (kB/sec): (3915000/27623)
IV size: 16 bytes
Anti replay bitmap:
outbound esp sas:
spi: 0x446005A9 (1147143593)
IV size: 16 bytes
Anti replay bitmap:
HQ-ASA# show crypto ipsec stats
IPsec Global Statistics
Active tunnels: 2
Previous tunnels: 8
Inbound
Bytes: 410004
Decompressed bytes: 410004
Packets: 4881
Dropped packets: 0
Replay failures: 0
Authentications: 4881
Authentication failures: 0
Decryptions: 4881
Decryption failures: 0
TFC Packets: 0
Decapsulated fragments needing reassembly: 0
Outbound
Bytes: 411012
Uncompressed bytes: 411012
Packets: 4893
Dropped packets: 0
Authentications: 4893
Encryptions: 4894
Encryption failures: 0
TFC Packets: 0
Fragmentation successes: 0
Pre-fragmentation successses: 0
Post-fragmentation successes: 0
Fragmentation failures: 0
Pre-fragmentation failures: 0
Post-fragmentation failures: 0
Fragments created: 0
PMTUs sent: 0
PMTUs rcvd: 0
Protocol failures: 0
Missing SA failures: 0
System capacity failures: 0
Inbound SA delete requests: 17
Outbound SA delete requests: 0
Inbound SA destroy calls: 17
Outbound SA destroy calls: 6
and interfaces status:
HQ-ASA# show interface Tunnel 10
Interface Tunnel10 "primary_vti", is up, line protocol is up
Hardware is Virtual Tunnel    Description: PRIMARY_VTI
        MAC address N/A, MTU 1500
        IP address 10.0.0.1, subnet mask 255.255.255.254
  Traffic Statistics for "primary_vti":
        0 packets input, 0 bytes
        1 packets output, 28 bytes
        0 packets dropped
      1 minute input rate 0 pkts/sec,  0 bytes/sec
      1 minute output rate 0 pkts/sec,  0 bytes/sec
      1 minute drop rate, 0 pkts/sec
      5 minute input rate 0 pkts/sec,  0 bytes/sec
      5 minute output rate 0 pkts/sec,  0 bytes/sec
      5 minute drop rate, 0 pkts/sec
  Tunnel Interface Information:
        Source interface: primary       IP address: 10.10.10.1
        Destination IP address: 20.20.20.1
        Mode: ipsec ipv4        IPsec profile: PROFILE1
HQ-ASA# show interface ip brief
Interface                  IP-Address      OK? Method Status                Protocol
GigabitEthernet0/0         192.168.123.1   YES CONFIG up                    up
GigabitEthernet0/1         10.10.10.1      YES CONFIG up                    up
GigabitEthernet0/2         30.30.30.1      YES CONFIG up                    up
GigabitEthernet0/3         unassigned      YES unset  administratively down up
GigabitEthernet0/4         unassigned      YES unset  administratively down up
GigabitEthernet0/5         unassigned      YES unset  administratively down up
GigabitEthernet0/6         unassigned      YES unset  administratively down up
Management0/0              unassigned      YES unset  administratively down up
Tunnel10                   10.0.0.1        YES CONFIG up                    up
Tunnel20                   10.0.0.3        YES CONFIG up                    up
You might also see:
CLI Book 3: Cisco ASA Series VPN CLI Configuration Guide, 9.7
I hope to be helpful.
Ben F
I was going to post something just like this as I was building what I believe would be the necessary configuration. Each site would have 2 public IPs and would try to use primary-primary, backup-primary, primary-backup, backup-backup in that order. I have 2 more VTI interfaces and more track objects for this. It does seem that using crypto map with 2 peer IP addresses is less involved than this, but that doesn't support IKEv2.
crypto ikev2 policy 10
 encryption aes-256
 integrity sha256
 group 2
 prf sha256
 lifetime seconds 28800
crypto ikev2 enable OUTSIDE
crypto ipsec ikev2 ipsec-proposal S2S_PROPOSAL
 protocol esp encryption aes-256
 protocol esp integrity sha-256
crypto ipsec profile S2S_PROFILE
 set ikev2 ipsec-proposal S2S_PROPOSAL
tunnel-group 1.1.1.1 type ipsec-l2l
tunnel-group 1.1.1.1 ipsec-attributes
 ikev2 remote-authentication pre-shared-key key123
 ikev2 local-authentication pre-shared-key key123
tunnel-group 2.2.2.2 type ipsec-l2l
tunnel-group 2.2.2.2 ipsec-attributes
interface tunnel 1
 nameif A_TO_B_VPN_1
 description "PRIMARY LINK TO SITE B MAIN IP"
 ip address 192.168.168.1 255.255.255.252
 tunnel source interface OUTSIDE
 tunnel destination 1.1.1.1
 tunnel protection ipsec profile S2S_PROFILE
interface tunnel 2
 nameif A_TO_B_VPN_2
 description "SECONDARY LINK TO SITE B MAIN IP"
 ip address 192.168.168.5 255.255.255.252
 tunnel source interface BACKUP
interface tunnel 3
 nameif A_TO_B_VPN_3
 description "PRIMARY LINK TO SITE B ALTERNATE IP"
 tunnel destination 2.2.2.2
interface tunnel 4
 nameif A_TO_B_VPN_4
 description "SECONDARY LINK TO SITE B ALTERNATE IP"
route A_TO_B_VPN_1 10.0.0.0 255.255.255.0 1.1.1.1 1 track 1
route A_TO_B_VPN_2 10.0.0.0 255.255.255.0 1.1.1.1 10 track 2
route A_TO_B_VPN_3 10.0.0.0 255.255.255.0 2.2.2.2 20 track 3
route A_TO_B_VPN_4 10.0.0.0 255.255.255.0 2.2.2.2 30
sla monitor 1
 type echo protocol ipIcmpEcho 1.1.1.1 interface OUTSIDE
 num-packets 3
 frequency 10
sla monitor 2
 type echo protocol ipIcmpEcho 1.1.1.1 interface BACKUP
 num-packets 3
 frequency 10
sla monitor schedule 2 life forever start-time now
track 2 rtr 2 reachability
sla monitor 3
 type echo protocol ipIcmpEcho 2.2.2.2 interface OUTSIDE
 num-packets 3
 frequency 10
sla monitor schedule 3 life forever start-time now
track 3 rtr 3 reachability
!Don't forget your NAT exemptions
nat (INSIDE,OUTSIDE) source static LOCAL_LAN LOCAL_LAN destination static REMOTE_LAN REMOTE_LAN no-proxy-arp route-lookup
nat (INSIDE,BACKUP) source static LOCAL_LAN LOCAL_LAN destination static REMOTE_LAN REMOTE_LAN no-proxy-arp route-lookup
!You also need to allow ICMP between the sites
icmp permit <REMOTE_PRIMARY_IP> OUTSIDE
icmp permit <REMOTE_SECONDARY_IP> BACKUP
When you run a "show track" you will see your primary->secondary shows as "down" if the far end is not failing. This is due to the far end using its primary WAN as its default route.
Ahmad Saad4
Hi there!
Can you run OSPF over the VTI (tunnle10 & tunnel20)?
JesseSmith8517
Is there a similar document for those who want to use BGP for routing instead of static routing?
