I configured very easy the SSL in RV345 Vpn router, according this doc: https://www.cisco.com/c/en/us/support/docs/smb/routers/cisco-rv-series-small-business-routers/smb5519-configure-secure-sockets-layer-virtual-private-network-ssl-v.html
I tried to find some docs for anyconnect client configuration, and I found only for ASA so I use it, but I cannot connect at all.
I need some help to configure the client for win7. I don't have any certificate, so in VPN router for certificate I use default option. If anyone succeed to configure in connection with RV345 please help me. Thank you
