haider_it
I had a problem to implement Cisco ACS radius server with Huawei switches
I made some Google searches and didn't find any article covering this specific issue
so i arranged some configuration steps and it was working successfully using Cisco ACS v 4.2 and the client as Huawei quidway S5600
the attached file showing the basic steps.
I still have problem how to import the commands log and accounting packets using TACACS+ or how to implement HWTACACS to achieve this puprose
regards
Haider Alshami
David Marquez
   Hello my friend,
  I would like to know if there is any chance to authenticate a Huawei switch with my ACS v4.2.
   It could be authenticated by Radius or TACACS. ???
  When I try to config the ACS with the option "Authenticate Using" i got this.
TACACS+ (CISCO IOS)
RADIUS (CISCO AIRESPACE)
RADIUS (CISCO AIRONET)
RADIUS (CISCO BBSM)
RADIUS (3COMUSR)
RADIUS (CISCO IOS/PIX 6.0)
RADIUS (CISCO VPN 3000/ASA/PIX 7.X+)
RADIUS (CISCO VPN 5000)
RADIUS (IETF)
RADIUS (ASCEND)
RADIUS (JUNIPER)
RADIUS (NORTEL)
RADIUS (Ipass)
   Which one Do I have to select to authenticate a Huawei Switch.
