Jeet Kumar
Introduction:
This document describes the process of configuring L2TP over IPSEC between Cisco IOS router and windows 7 and user authentication is using RADIUS.
Prerequesites
This document requires a basic understanding of IPSec protocol. To learn more about IPSec, please refer to An Introduction to IP Security (IPSec) Encryption.
Components Used:
Cisco IOS® Software Release 12.4
Cisco 2961 router
Windows 7 machine (Client)
Windows 2008 server (Running RADIUS protocol)
Configuring AAA parameters:
We are talking about user authentication here. This authentication is done within L2TP framework, not IPSec. Depending on a LAC/LNS combination, and user database we are using, there are several choices here:
  • PAP
  • CHAP
  • MS-CHAPv1
  • MS-CHAPv2
  • EAP
I would like to point out that all of these methods, except for some EAP types, are not considered secure and there are tools and ways of breaking these methods.
https://popravak.files.wordpress.com/2013/03/snaghtml637c61.png
Diagram:
Configuration on Cisco IOS router:
aaa new-model
aaa authentication ppp l2tp group radius local
vpdn enable
vpdn-group L2TP
! Default L2TP VPDN group
 accept-dialin
  protocol l2tp
  virtual-template 1
 no l2tp tunnel authentication
crypto isakmp policy 1
 encr 3des
 authentication pre-share
 group 2
 hash sha
 lifetime 86400
crypto isakmp key cisco address 0.0.0.0 0.0.0.0
ip local pool l2tp-pool 192.168.1.1 192.168.1.100
crypto ipsec transform-set L2TP-Set esp-3des esp-sha-hmac
 mode transport
crypto dynamic-map dyn-map 10
 set transform-set L2TP-Set
crypto map outside_map 65535 ipsec-isakmp dynamic dyn-map
interface Loopback1
 ip address 192.168.1.10 255.255.255.0
interface FastEthernet0/0
 ip address 192.168.2.1 255.255.255.0
 ip nat inside
 ip virtual-reassembly
 duplex auto
 speed auto
interface FastEthernet0/1
 ip address 47.47.47.100 255.255.255.0
 ip nat outside
 duplex auto
 speed auto
interface Virtual-Template1
 ip unnumbered Loopback1
 peer default ip address pool l2tp-pool
 ppp authentication ms-chap-v2 l2tp
ip route 0.0.0.0 0.0.0.0 47.47.47.47
ip nat inside source list nat interface FastEthernet0/1 overload
ip access-list extended nat
 deny   ip 192.168.2.0 0.0.0.255 192.168.1.0 0.0.0.255
 permit ip 192.168.2.0 0.0.0.255 any
radius-server host 192.168.2.100
radius-server key cisco123
end
Configuration on Windows Machine:
1. Click on Start and select Control Panel:
2. Select Network and Sharing center :
3. Select "Set up a new connection or network":
4. Select "Connect to a workplace:
5. Select Use my Internet Connection (VPN):
6. Add the public IP address of the ASA (IP on the outside interface of the ASA). Destination name is optional and you can choose anything of your choice and then click on NEXT:
7. Add the username and the password and select "Remember Password" and click on create:
8. In the network and sharing center you will see the connection tab, right click on and click on Properties.
9. In the general TAB make sure the IP address is correct.
10. In the security TAB make sure that type of connection is set to L2TP/IPsec.
11. Go to Advanced settings and add the pre-shared key
12. In the Security, under allow these protocols select MS-CHAP v2 and then click on OK.
13. Double click on L2TP icon and you will get the connection window. Make sure username and passwords are correct. Then click on Connect. And if everything else in place it will get connected :)
14. Once connected right click on the L2tP icon and click on status to see connection details:
Debugs are attached. you can also refer the following links for the L2tP configuration.
Configure L2TP on Cisco IOS using Local Authentication:
https://supportforums.cisco.com/document/9878401/l2tp-over-ipsec-cisco-ios-router-using-windows-8
Configure L2TP over IPsec on Cisco ASA 8.4 using Local Authentication:
https://supportforums.cisco.com/document/12375996/configure-l2tp-over-ipsec-using-cisco-asa-84-and-local-authentication
Configure L2TP over IPsec on Cisco ASA 8.4 using LDAP Authentication:
https://supportforums.cisco.com/document/12376016/configure-l2tp-over-ipsec-using-cisco-asa-84-and-ldap-authentication
coryalbert
Cisco 2951 router
Jeet Kumar
coryalbert  i didn't understand your question.
REsafarov1
Community Member
You should add the command bellow to make this thing working.
aaa authorization network default if-authenticated
itscomputers
Please provide a configuration example for the 4321 router IOS 15.5 (release 3.16.04B.S) to act as VPDN server L2TP protocol for windows 10 L2TP clients
Thank you,
