4507R+SUPII_Plus Redundancy Problem
sbjeong
Dear Professionals
I have
4507R + 2 X SUPII_Plus + cat4000-i9s-mz.121-19.EW1.bin
Following dump seems to be not configured correctly to redundancy.
What can I do to fix this problem.
------------------ show running-config --------------
redundancy
mode rpr
main-cpu
auto-sync startup-config
auto-sync standard
7507R_SUPII_Plus#show redundancy stat
my state = 13 -ACTIVE
peer state = 1 -DISABLED
Mode = Simplex
Unit = Primary
Unit ID = 1
Redundancy Mode (Operational) = RPR
Redundancy Mode (Configured) = RPR
Split Mode = Disabled
Manual Swact = Disabled Reason: Simplex mode
Communications = Down Reason: Simplex mode
client count = 4
client_notification_TMR = 60000 milliseconds
keep_alive TMR = 9000 milliseconds
keep_alive count = 0
keep_alive threshold = 18
RF debug mask = 0x0
7507R_SUPII_Plus#redundancy force-switchover
There is no STANDBY present. Failed to force switchover
Best Regards
vkapoor5
Level 5
Level 5
The problem is with the following missed commands in your global configuration... Assuming Active RSP in slot 2, Standby RSP in Slot 3 and both RSP's have Slot 0 flash memory cards.
R(config)#hw-module slot 2 image slot0:
R(config)#hw-module slot 3 image slot0:
R#hw-module sec-cpu reset
Refer the following links for more information...
http://www.cisco.com/en/US/products/sw/iosswrel/ps1612/products_feature_guide09186a0080080a6f.html
http://www.cisco.com/univercd/cc/td/doc/product/core/cis7505/rte_swit/6586rsp8.htm#213565
