About N2K-C2232TM-E-10GE problem ?
HAOYOUJI123
what's wrong with this problem ?
When I insert the N2K-C2232TM-E-10GE  on  eth131/1/1 port ,but this port always  keep down status . and another port is OK
 Eth131/1/1  Down       Po131
 Eth131/1/2    Up       Po131
 Eth131/1/3    Up       Po131
what's wrong with this port ?
Does N2K-C2232TM-E-10GE  can not nonegotiate with 100M/bps server ?
Wes Austin
Checking here:
http://www.cisco.com/c/en/us/products/collateral/switches/nexus-2000-series-fabric-extenders/product_bulletin_c25-715278.html
I see:
Cisco Nexus 2232TM-E
32 x 1/10GBASE-T host interfaces and uplink module (8 x 10 Gigabit Ethernet fabric interfaces [SFP+]; superset of Cisco Nexus 2232TM)
This leads me to believe it will only do 1G or 10G, other models have 100/1000 listed for host interfaces.
100 MBps does not appear to be supported on the 2232TM-E-10GE.
HTH,
Wes
Wes Austin
Checking here:
I see:
HTH,
Wes
Hi Wesley Austin
thanks for you
The N2K-C2232TM-E-10GE has connected the avaya voice switch & this port  also down status .
what's wrong ?did the  N2K-C2232TM-E-10GE can not support voice switch ?
        from Hao
Does the Avaya switch support 1000 mbps?
Make sure the interface on the Fex is set for:
- Auto-negotiation or statically set for 1000 and not 10000
-Is this copper or fiber?
-Duplex settings on the Avaya switch set correctly
- Does the link come up on the Avaya if you plug a PC in to the same link?
-Does the FEX HIF come up if you plug in a PC to it's interface
-Have you tried other cables/optics if applicable?
If you provide some further info, I will be glad to assist.
-Wes
