AS/400 to Two 5494 controllers using STUN
tholmes
I've configured STUN between an AS/400 and 2 x 5494 controllers across a serial link using two 2621 routers
I've pretty much copied the configuration from the example web site which shows this exactly as we have it
http://www.cisco.com/en/US/partner/tech/tk827/tk369/technologies_tech_note09186a00800b451e.shtml
The IBM engineer is saying the RTS lines never drop so he is not able to activate either controller.
Can you give the config a quick look and possibly tell me where I'm going wrong please
Many thanks
Tony
hostname Site_A
stun peer-name 172.16.1.1
stun protocol-group 1 sdlc
stun remote-peer-keepalive 10
interface Loopback0
ip address 172.16.1.1 255.255.255.0
interface Serial0/0
description *** Kink to Site B ***
bandwidth 960000
ip address 192.168.200.2 255.255.255.252
priority-group 1
interface Serial0/1
description *** Link to AS/400 ***
no ip address
encapsulation stun
idle-character marks
nrzi-encoding
clockrate 19200
stun group 1
stun sdlc-role secondary
sdlc K 1
sdlc address 01
sdlc address 02
stun route address 1 tcp 172.16.2.1 local-ack
stun route address 2 tcp 172.16.2.1 local-ack
ip route 0.0.0.0 0.0.0.0 192.168.0.1
priority-list 1 protocol stun high
priority-list 1 protocol ip medium tcp 1990
priority-list 1 protocol ip normal tcp 1991
priority-list 1 protocol ip low tcp 1992
priority-list 1 protocol stun high address 1 1
priority-list 1 protocol stun high address 1 2
hostname Site_B
stun peer-name 172.16.2.1
interface Loopback0
ip address 172.16.2.1 255.255.255.0
interface Serial0/0
description *** Serial Link to Site A ***
bandwidth 960000
ip address 192.168.200.1 255.255.255.252
no ip route-cache
no ip mroute-cache
priority-group 1
interface Serial0/1
description Serial Link to 5494 Controller 01
no ip address
encapsulation stun
no ip route-cache
no ip mroute-cache
nrzi-encoding
clockrate 19200
stun group 1
stun sdlc-role primary
sdlc address 01
stun route address 1 tcp 172.16.1.1
interface Serial0/2
description Serial Link to 5494 Controller 02
no ip address
encapsulation stun
no ip route-cache
no ip mroute-cache
nrzi-encoding
clockrate 19200
stun group 1
sdlc address 02
stun route address 2 tcp 172.16.1.1
ip route 0.0.0.0 0.0.0.0 192.168.200.2
mbinzer
not sure but my best guess would be that it makes not much sense to have local-ack on routera but not on routerb. Either on both or on none.
thanks...
Matthias
Thanks Matthias, I think it's a locally significate configuration, might be worth looking at
Regards Tony
No, it is not only locally significant. It is either local-ack or not per stun group on both sides
jihicks
Hi Tony,
The first thing is that this line has clock rate configured, which must mean it is DCE ( has a DCE cable attached ). This means RTS comes from the AS/400 and not the router. CTS would come from the router. If you want this to work as half duplex, add half-duplex to the serial interface configuration. Also, you should add the global command, "stun quick-response" on the AS/400 side router only. Local-ack is by STUN group, all of none. "Stun quick-response" is only valid with local-ack. It prevents the AS/400 from taking the line down if one of the remote controllers is down. This allows the other to stay up. The router will respond with DM for the controller that is down.
Best regards,
Jim
