Cisco nexus 5596 + fex and connect other network device...
lchorebala
I need connect to fex 2248 (nexus 5596) network devices (cluster F5 LTM, blade infrastrukture, and other).
I need reliable information, can I connect these devices.
What are the limits, what are the risks ...
Lukasz
richbarb
You can connect anything that behaves like a host to the network in the fex. (hosts do not process STP bpdu).
I mean, if a device send bpdu, it can't be connected to the fex port or the port will be automatically disabled.
Besides this rule, you have to be aware in the east-west traffic. All traffic that goes to FEX, must go to upstream switch, even if have to come back to another port in the same fex.
Regards.
Richard
Amit Singh
Hi Lukasz,
As Richard mention, its is not supported to connect any network device which can send/receive BPDU connected to the FEX ports. Even if you connect some of the network devices routers, F/W's  and IPS devices, its still not supported. I had a recent TAC experience where we had some issues regarding the ASA/Router peering using the FEX ports and TAC made customer move all teh devices to 5K else they would not support the issue.
So the offcial statement is please do not connect anything except Hosts/Servers to your FEX ports.
Cheers,
-amit singh
