cisco Nexus5548 running high cpu due to snmpd process
Please help,
I am running Nexus 5548 as a vpc peers and their configuration are the same, however on of the nexus 5k is running 60-70% of CPU and the snmpd is consistently above 40%, can anybody help please.
Hardware
  cisco Nexus5548 Chassis
Software
  BIOS:      version 3.5.0
  loader:    version N/A
  kickstart: version 5.0(3)N2(1)
  system:    version 5.0(3)N2(1)
Nexus-5K-B# sh processes cpu sort
PID    Runtime(ms)  Invoked   uSecs  1Sec    Process
 4596           80  559614080      0   43.0%  snmpd
 4622          180        86   2098    9.0%  netstack
    1         1854  15594452      0    0.0%  init
NL-DC-5K-39B# sh proc cpu histo
    595655555565555578555555555555566656555555555555559555567555
    867368678798799811786986599987901960697989967667775877600876
100  #                                                #
 90  #                                                #
 80  #               #                                #
 70  #        #     ##               #                #     #
 60 ############################################################
 50 ############################################################
 40 ############################################################
 30 ############################################################
 20 ############################################################
 10 ############################################################
    0....5....1....1....2....2....3....3....4....4....5....5....
              0    5    0    5    0    5    0    5    0    5
               CPU% per second (last 60 seconds)
                      # = average CPU%
       1          1          1          1          1          1
    997089889899880878978788808878778788088888888890898999998909
    869011665931590779138644100361880912035544567860918455765709
100 ** *    *     *          *          *         **    **** ***
 90 ** * *********** ** *    *          * **  ******************
 80 ***#**********#**** *****#**********#**********#**********#*
 70 ***#**********#**********#**********#**********#**********#*
              0    5    0    5    0    5    0    5    0    5
               CPU% per minute (last 60 minutes)
              * = maximum CPU%   # = average CPU%
    778777777777777777777777777777777777777777777777777777777777777777777777
    760778787777778777777777877777667878787777877878687777677777777777777677
100
 90
 80 ************************************************************************
 70 ************************************************************************
 60 ########################################################################
 50 ########################################################################
 40 ########################################################################
 30 ########################################################################
 20 ########################################################################
 10 ########################################################################
    0....5....1....1....2....2....3....3....4....4....5....5....6....6....7.
              0    5    0    5    0    5    0    5    0    5    0    5    0
                   CPU% per hour (last 72 hours)
Mark Malone
hi
looks like there are problems with that version and snmp , have you tried restarting the 5k does it constantly creep back up to high levels for that process ?
you could try the below as temp fix on switch that's effected in the support forum link  , it should restart the snmpd process , may fix it
https://supportforums.cisco.com/discussion/11363941/snmp-nexus-5548-failing
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCtr65682
couple of good tshoot commands specific for snmp as well in this doc for 5ks
http://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus5000/sw/troubleshooting/guide/N5K_Troubleshooting_Guide/n5K_ts_sm.html#pgfId-1024645
Mark Malone
hi
Thanks Mark,
I will try the temp fixes and feedback to you.
Thank you for the advise.
