I would like to know whether Cisco SX550X Switches are compatible with Dell EMC VxRail HCI.
Got the below prerequisites from VxRail configuration guide, need to whether Cisco SX550X can work with these conditions;
The switch(es) must support both IPv4 and IPv6 network protocols.
- The switch(es) connected directly to VxRail nodes must support multicast on switch ports for all models of VxRail.
- VxRail releases earlier than v4.5.0: both IPv4 and IPv6 multicast pass-through must be supported. Layer 3 multicast is not required. –
VxRail releases starting with v4.5.0: IPv6 multicast pass-through and IPv4 unicast must be supported.
