Configure priority flow control
vbhanu123
Community Member
I am trying to configure priority flow control  on a Nexus 5020 (IOS 4.1(3)N1(1)). I have enabled it on the relevant  ports and am trying to enable priority flow control for traffic with cos  values 2 and 4. My configuration looks as below (output of $show policy-map system).
I  am classifying traffic in these priority classes into a qos-group (4)  and then make this entire traffic a no-drop class (using the policy-map  cosPolicy). But what I observe is that when I send a pause control  packet to pause traffic with cos value 2, it pauses both cos 2 and cos 4  traffic. My hypothesis is that this is a head-of-line blocking issue  though I do not understand why that should be happening.
(the same configurations work ok when I create two qos-groups, one for each cos traffic and then two pause no-drop classes).
Any help on this issue would be extremely helpful.
Bhanu
  Type network-qos policy-maps
  policy-map type network-qos cosPolicy
     class type network-qos cosClass      match qos-group 4
      pause no-drop
       mtu 9216
     class type network-qos class-fcoe      match qos-group 1
      pause no-drop
       mtu 2240
     class type network-qos class-default      match qos-group 0
      mtu 9216
   Service-policy (qos) input:   cosGroup
     policy statistics status:   disabled
    Class-map (qos):   cosClass (match-any)
       Match: cos 2,4
       set qos-group 4
    Class-map (qos):   class-fcoe (match-any)
       Match: cos 1
       set qos-group 1
    Class-map (qos):   class-default (match-any)
       Match: any
       set qos-group 0
  Service-policy (queuing) input:   default-in-policy
    Class-map (queuing):   class-fcoe (match-any)
       Match: qos-group 1
       bandwidth percent 50
    Class-map (queuing):   class-default (match-any)
       Match: qos-group 0
  Service-policy (queuing) output:   default-out-policy
       Match: qos-group 1
       Match: qos-group 0
0 Replies 0
