Connect directly Nexus 7010 to Nexus C2248TP-1GE
jacinto1m
Can somebody confirm if the below devices can be connected directly?
I am willing to buy the two devices which specs are in the attached file but I wanted to confirm first if it is possible to connect them directly!
Any help is much appreciated!
andrew.prince
Level 10
Level 10
yes I can confirm you can connect the directly, I have finished a project connecting 4x 2k to 2x 7k and all works ok. And note, if you want to run vpc to host connected to the 2k you need software ver 5.2.1
I also connected the, using twinax not 1g fibre, but I am not 100%......as your reseller.
