DLSW Problem...
abekeris
Level 2
Level 2
Have a problem trying to stablish a circuit between two VMS systems. It was working and one day it didn't work anymore.
The circuit stucks at CKT_START (any idea of what we have to do ?):
3741319329 4000.1347.4124(04) 4000.1347.4151(04) CKT_START -
PCEP: 62FD7218 UCEP: 623400FC
Port:TB1 peer 192.168.210.188(2065)
Flow-Control-Tx CW:20, Permitted:0; Rx CW:20, Granted:0; Op: Repeat
Congestion: Low(02), Flow Op: Half: 0/0 Reset 0/0
RIF = --no rif--
Bytes: 0/0 Info-frames: 0/0
XID-frames: 0/0 UInfo-frames: 0/0
mbinzer
the first thing i would do if you need help in troubleshooting is to open a Service Request with cisco's tac.
If things used to work and suddenlly stopped to work than the question always is what has changed??
There are lots of potentiall issues in the chain one can look at. I would advice to open a SR and work the issue with the tac until conclusion.
thanks...
Matthias
Michael Stuckey
Level 5
Level 5
Did you ever get a resolution to this? I am just curious. I would bet one of the VMS systems was causing the problem.
Mike
