First Time UCS Firmware Upgrade
elliottj1
Hey everyone. I am new to UCS only since August 2015. So, I am a little timid about a request TAC has put on me.
Currently we are running firmware 2.1(3A) across our UCS server systems. We have a server today that is causing an issue, which is relevant to a new bug they found in this firmware.
They are requesting I upgrade to another Firmware. However, I have no test environment, so I am stuck 1. Trying to choose the best firmware. Looks like 2.2 (6e) is the latest. We are running Vmware 5.1. All systems SAN Boot over FC.
I have a word document TAC gave me on the upgrade instructions, looks simple enough. I am just also worried about the ability to roll back to an older firmware if issues crop up with a newer version.
They also indicated upgrading firmware will cause no downtime. Call me crazy (since I am new to UCS) but how is it possible to upgrade the firmware on a Host without it rebooting?
Thanks for all the thoughts.
Clifford Aldan
Follow the guide Upgrading Cisco UCS from Release 2.1 to Release 2.2 to perform the upgrade
UCS upgrading is a 3-phase approach
Phase 1: Upgrading UCS infrastructure components
  • Infrastructure components consist of the UCS Manager software, the Fabric Interconnects, and the IO Modules on each Chassis
  • The FIs reboot one at a time, starting with the secondary
  • The guide discusses verifying that the path is up before proceeding with the primary, which won't reboot on its own - requires manual execution to perform
  • When the FI reboots, all IOMs connected to that FI will reboot as well, effectively downing that path
  • During the FI reboots, only one path is down at any given time, so the network itself is still available, albeit in a degraded state (one path at a time until both FIs/IOMs have been upgraded)
Phase 2: Upgrading UCS blade server firmware
  • Performed via Host Firmware Package policy
  • Upgrades the CIMC, BIOS, Board Controller, CNA/Network Adapters, Storage controllers, etc
  • Ensure maintenance policy is set to "User Ack" to prevent instant reboot of all blades
  • With "User Ack" enabled, this allows rebooting of the blades to be staggered
  • Perform reboot of each host for the policy to take affect
    • For example, if your blades are running VMware ESXi and are members of an ESXi cluster with HA/DRS enabled, you can set each ESXi host into maintenance mode (to evac all VMs off that host safely) and reboot them one by one
    • Once the server is done, it will be back online and can exit maintenance mode to host VMs
Phase 3: Upgrading OS network and storage drivers
  • Not mentioned in the upgrade guide, but is necessary to ensure drivers are meeting compatibility based on the UCS release
  • Refer to the Cisco UCS HW and SW Interoperability utility for more information on supported drivers
