Help me please
abdulrahman.alsalim
Community Member
I am new member and new learner and i want your help to configure Web Server(HTTP) - i tried so many things and it still don't let me go to the browser.
Any one have an idea an can help me please ?
I will upload the .pkt file and i am waiting for your solutions
luis_cordova
Hi @abdulrahman.alsalim
Assign the correct vlan to the indicated interfaces.
Fa0/8 = VLAN 60
Fa0/9 = VLAN 70
In the MultiLayer switch you must create vlan 60 and vlan 70, since the vlan interfaces only remain UP if the corresponding vlan is created in the switch
In the MultiLayer switch you must change the ip assigned to the vlan60 interface, since this must be 192.168.60.1.
I attach the exercise with these changes.
Remember to mark the correct answers as solved, because that helps other users with similar questions
luis_cordova
Fa0/8 = VLAN 60
Fa0/9 = VLAN 70
Thank you so much it's a very helpful answer , thanks from the heart ❤
