how to do ingress policing on Nexus 5548 up?
zterilized
As the topic
Can i classified the group of ip with access-list , bind it with class-map type qos, and bind the class-map to policy-map type qos, do the policing, then apply to a destine interface by service policy input. Whoever ever do like this before?
I have the problem that when i have applied the policy to the interface, i do show policy interface for the statistic, and the traffic always drop in class-default!!!! Cisco guy please help!!!!
zterilized
I have try to applied the access-list directly to the interface and it was good , but when it linked to qos class-map . Lookalike doing nothing
zterilized
I done the same command on the N7K and it's working like a charm, why it's not work on N5K?
My brief configuration
Type qos policy-maps
  policy-map type qos police
    class type qos cmap-ftp
      police cir 10 mbps bc 1000 bytes conform transmit violate drop
    class type qos class-default
      set qos-group 0
      police cir 20 mbps bc 10000 bytes conform transmit violate drop
  Type qos class-maps
    class-map type qos match-all cmap-ftp
      match access-group name test2
IPV4 ACL test2
        10 permit ip any any
IPV4 ACL ftp
        10 permit tcp any any range 1024 65000
Result
Ethernet1/21
  Service-policy (qos) input:   police
    policy statistics status:   enabled
    Class-map (qos):   cmap-ftp (match-all)
      Match: access-group test2
        conformed 0 bytes, 0 bps action: transmit
        violated 0 bytes, 0 bps action: drop
    Class-map (qos):   class-default (match-any)
      Match: any
      set qos-group 0
        conformed 102613288 bytes, 0 bps action: transmit
        violated 32766831 bytes, 0 bps action: drop
PS:
FTP server connect to interface e1/21 on this switch.
FTP Client connect to another switch(N5K) which connect to this switch via peer-link
zterilized
Sh run of interface e1/21
!Command: show running-config interface Ethernet1/21
!Time: Tue May 21 06:48:57 2013
version 6.0(2)N1(2)
  switchport access vlan 575
  speed 1000
  service-policy type qos input police
