HSRP Issue on Nexus 9k
Garry Cooper
Hi All.
I have 2 datacentres with a pair of Nexus 9k (9364c) at each site running hsrp.
With HSRP setup between the 4 site, I lose default route access to our firewall.
Default route 0.0.0.0/0 172.17.0.4 is to our firewall.
HA for the firewalls is across the 10GB InterDC layer 2 Link
The engineer that initially setup the Nexus9k added an acl that blocks the hsrp between the DC's
This works now and I can access the firewall by the default route, but not sure why the hsrp is not working correctly if I remove this acl.
Attached an diagram of setup
Any ideas guys.
IP access list HSRP_ISOLATON
5 permit ip 10.249.9.0 0.0.0.15 any log
10 deny udp any 224.0.0.2/32 eq 1985
20 deny udp any 224.0.0.102/32 eq 1985
30 deny udp any 224.0.0.18/32 eq 1985
40 permit ip any any
Sergiu.Daniluk
Hi @Garry Cooper
I suppose that you have 2x VPC domains, one in each DC. If this is true, then the HSRP isolation is required to avoid the situation of HSRP Active + HSRP Listening in one DC and HSPR Standby + HSRP Listening in the other DC.
If you arrive in this situation, then the HSRP Listening node will "try" to route the traffic (because of the vPC), but since it cannot really route, the traffic black holed.
Additional details about HSPR isolation: https://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus9000/sw/7-x/interfaces/configuration/guide/b_Cisco_Nexus_9000_Series_NX-OS_Interfaces_Configuration_Guide_7x/b_Cisco_Nexus_9000_Series_NX-OS_Interfaces_Configuration_Guide_7x_appendix_011...
Sergiu
Sergiu.Daniluk
Hi @Garry Cooper
Sergiu
