iSCSI & Server LAN Traffic in Same Trunk Port
michaelgitonga
I plan to use a Cisco UCS Rack mountable C200 server with a dual port PCIe card with TOE iSCSI. Is it acceptable to:
  • To use just one dual port PCIe card for both iSCSI storage traffic and server LAN traffic - separated by VLANs? - With the ports connected two upstream swtches (for redundancy) and the switch ports configured as Trunks for both iSCSI & data VLANs??
  • To use 1GE TOE iSCSI ports instead of 10GE TOE iSCSI ports
  • To use a TOE iSCSI port for server data VLAN traffic??
michaelgitonga
I forgot to add that I'm using VMware Esxi 5 hypervisor.
Yes doable. Also you can mark iSCSI with cos 2 and 9000 MTU with certain badwidth gaurantee for your iSCSI traffic and rest stays in default queue.
class-map type qos iSCSI-qos-class
     match cos 2
policy-map type qos iSCSI-qos-policy
     class iSCSI-qos-class
          set qos-group 2
     class class-default
          set qos-group 0
class-map type queuing iSCSI-queuing-class
     match qos-group 2
policy-map type queueing iSCSI-queuing-policy
     class type queuing iSCSI-queuing-class
          bandwidth percent 30
     class type queuing class-default
          bandwidth percent 70
class-map type network-qos iSCSI-network-class
     match qos-group 2
policy-map type network-qos iSCSI-network-policy
     class type network-qos iSCSI-network-class
          mtu 9216
          mtu 1500
system qos
     service-policy type qos input iSCSI-qos-policy
     service-policy type queueing output iSCSI-queuing-policy
     service-policy type network-qos iSCSI-network-policy
