LMS Problem
ayman emara
Hi all,
can any one tell me about the attached taken screenshot of an error
i do not know why it appeared and what is its cause.
Thanks in advance
Ayman Yehia
balbaletabrez
Hi...
Your 90 Days evaluation version of LMS doesnt support devices more then 100.
Better buy license for the same ASAP.
Tabrez
Dear Tabrez,
We have already a license for it but all what we did is re-installing the LMS server before that.
does it seems to be the problem ???
Best Regards,
Ayman Yehia
Can you create a group and try to discover the devices in that test group and try.
If it works there then your old group/profile might be having problem so you need to delete the old group and create a new one.
Tabrez
