Matriz de compatibilidad firmware Cisco B22HP, HP C7000 y Proliant BL460c G7, Gen8 y Gen9
davidescobar
Buenos dias, vamos a conectar 2 Cisco Fabric Extender B22HP en un enclosure C7000 con Blades Proliant G7, Gen8 y Gen9. Queriamos saber si hay alguna matriz de compatibilidad de firmware de todos estos productos para asegurarnos que no va a haber ningĂșn problema.
Muchas gracias y un saludo
Thanks Kirk, but I was looking for the Firmware Compatibility Matrix. I found this compatibility matrix for the C7000 and the Proliant BL460c but with Virtual Connect (http://h20564.www2.hpe.com/hpsc/doc/public/display?docId=mmr_kc-0100204). I have asked HPE and they have indicated that the compatibility matrix for the B22HP has to be provided by the manufacturer of the product, Cisco.
The only thing I have found is this Cisco B22 link (http://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus2000/B22/HP_B22FEXGSG.html#wp744232) dated 2012 shows that a version of OA 3.3 is needed.
