Maximum supported VDC in nexus 9504
Siddharam M
We are having a nexus 9504 switch with SUP-A installed in it.
IOS version: NX-OS 7.0.3(I1)2 and we are planning to create more VDC's in it. But in one of the release notes i have read that Nexus 9k does not support multiple vdc's.
The Cisco Nexus 9000 Series switches currently do not support multiple VDCs. All switch resources are managed in the default VDC.
http://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus9000/sw/6-x/high_availability/guide/b_Cisco_Nexus_9000_Series_NX-OS_High_Availability_and_Redundancy_Guide.pdf
But above release notes is for Nexus 6.x and we are running 7.x. can someone confirm whether Nexus 9K supports Multiple VDCs are not.
Thanks in advance,
Siddu
Rajeshkumar Gatti
Siddu,
The same is true for 7.x release and documented in the link below-
http://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus9000/sw/7-x/interfaces/configuration/guide/b_Cisco_Nexus_9000_Series_NX-OS_Interfaces_Configuration_Guide_7x/b_Cisco_Nexus_9000_Series_NX-OS_Interfaces_Configuration_Guide_7x_chapter_010.html#concept_D8A671340D2D473DAA9CBD20BB42FC63
-Raj
Rajeshkumar Gatti
Siddu,
-Raj
