Mgmt0 for VDCs on same chassis can't communicate
Sean Lair
We have a Nexus 7700 running two different contexts.  One is the Admin context and then another standard context.  They are configured with IP addresses within the same subnet (10.101.0.0/24), but they can't communicate with each - other ping doesn't even work between them.
However, they can both talk to all other devices on that subnet just not each other...  I've included the output from some commands below along with the NX-OS version.  Both mgmt0 interfaces in each VDC have different MAC addresses as they should.
Is this a bug or am I missing something here?  The upstream switchport is just an access port.
Thanks for any help/insight anyone can provide!
Sean
version 6.2(8a)
Admin Context
show run int mgmt0
interface mgmt0
  vrf member management
  ip address 10.101.0.10/24
show int mgmt0
mgmt0 is up
admin state is up
  Hardware: GigabitEthernet, address: 8480.2da5.f3c4 (bia 8480.2da5.f3c4)
  Internet Address is 10.101.0.10/24
  MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec
  Encapsulation ARPA, medium is broadcast
  Port mode is routed
  full-duplex, 1000 Mb/s
  Auto-Negotiation is turned on
  Auto-mdix is turned off
  EtherType is 0x0000
  1 minute input rate 32 bits/sec, 0 packets/sec
  1 minute output rate 24 bits/sec, 0 packets/sec
  Rx
    188445 input packets 6622 unicast packets 181375 multicast packets
    448 broadcast packets 48204530 bytes
  Tx
    90779 output packets 20 unicast packets 90737 multicast packets
    22 broadcast packets 21779795 bytes
Other Context
show run int mgmt0
interface mgmt0
  ip address 10.101.0.11/24
show int mgmt0
mgmt0 is up
admin state is up
  Hardware: GigabitEthernet, address: 8480.2da5.f3c5 (bia 8480.2da5.f3c5)
  Internet Address is 10.101.0.11/24
  Port mode is routed
  EtherType is 0x0000
  1 minute input rate 696 bits/sec, 0 packets/sec
  1 minute output rate 696 bits/sec, 0 packets/sec
  Rx
    5647969 input packets 5466145 unicast packets 181376 multicast packets
    448 broadcast packets 495885390 bytes
  Tx
    5569760 output packets 5466115 unicast packets 92181 multicast packets
    11464 broadcast packets 474893154 bytes
6 Replies 6
Reza Sharifi
Since each interface is in a different VDC, they will not talk to each other.  Think of VDCs as 2 different switches.  Unless you connect the VDCs together the interfaces will not talk to each other.
Hi Reza, thanks for the reply.  I understand they are two different switches, but they both have IPs in the same subnet and thus should be able to talk to each other, through the external switch that mgmt0 is connected.  Here are the IPs assigned:
10.101.0.10/24
10.101.0.11/24
As seen above, they are in the same subnet and should be able to talk to each other across the network.
Sean
Hi Sean,
Are both ports in the same vlan on the external switch?
Hi Reza,
Since these are VDC, those IPs are all on the physical mgmt0 on the switch.   mgmt0 is physically shared across all VDC, so yes they are technically on the same VLAN.
Sean
Hi Sean,
Even though there is only one mgmt interface, each VDC gets its own management IP and can't talk to each other unless you connect the mgmt interface physically to an external switch.
from 7k documentation:
The out-of-band management interface (mgmt0) can be used to manage all VDCs. Each VDC has its own representation for mgmt0 with a unique IP address that can be used to send syslog, SNMP and other management information. The mgmt interfaces are not shared across multiple VDCs.
http://www.cisco.com/c/en/us/products/collateral/switches/nexus-7000-series-switches/white_paper_c11-701112.html
Hi Reza, the mgmt0 interface is physically connected to an external switch.  I can talk to all the mgmt IPs from other hosts on the network.  But from within a VDC I cannot even ping other mgmt0 IPs (of other VDCs)
