Bookmark
Subscribe
938
N5000 and vPC
gnijs
Level 4
Level 4
I know vPC supports multi-homing a FEX to two N5000. Also vPC allows to build a server portchannel across two single connected FEX.
Does vPC also support building a server portchannel across two FEX that are each dual connected to two N5000 ?
Is this on the road-map ?
iyde
Level 4
Level 4
Hi.
Currently NOT supported but as far as I know it'll be supported in the upcoming release this autumn.
HTH.
Is there any further documentation on all the included features of the new NX-OS release, and a release date?
I'd like to slide it in under our configuration freeze. It sure would fix a lot of stuff for me.
You might want to talk to your Cisco account team since some of these info might require NDA.
jerry
yes it is ( c`mon, everybody wants this.. ) otherwise you can't build LACP teamed interfaces.
If you have HPs w/recent code they auto-negotiate teaming ....
so ahead and configure everything as though it did work, just put both ports into the same VLAN and when it is available you can convert a server at a time to vPC for teaming.
But really ... aren't 2 ports from 2 different FEXs that can both service traffic good enough ?
And yes, I have servers setup this way.
