Need some help configuring the Nexus 1000v on vsphere
Avinash N.
Hi Folks,
   I am trying to create a virtual lab for dot1x and hence need to configure the N1k on the vsphere. I ve hit the following roadblocks and would be great if someone could help out.
Ive installed Nexus 5.2(1)SV3(3.15) on an ESXi 5.5(the only ISO i could get my hands on...6.5 complained about image profiles when installing the VIB)
1. Are VIBs common for all Nexus devices or are they tied to the Nexus? For example I have a VSM on another ESXi and i downloaded the VIBs from there and installed it on the current host and created a new VSM is this fine or should it be the same VSM. Since they are VIBs i would assume they are common for all.
2. I run
~ # vem status
VEM modules are loaded
Switch Name      Num Ports   Used Ports  Configured Ports  MTU     Uplinks
vSwitch0         1536        8           128               1500    vmnic0
DVS Name         Num Ports   Used Ports  Configured Ports  MTU     Uplinks
avinn-nexus      1024        14          1024              1500    vmnic1
VEM Agent (vemdpa) is running
and I can see my VEM is installed
I allocated a Distributed Port group for this with the following port profiles
port-profile type ethernet uplink
  switchport mode trunk
  no shutdown
  state enabled
  vmware port-group
port-profile type vethernet DOT1X_MAB
  switchport mode access
  switchport access vlan 100
  no shutdown
  state enabled
  vmware port-group
But on the VC i see the ports as admin blocked.
Since i have specified the VLAN and trunk on the port-profile i dont think there could be a Native vlan problem but on the Vsphere client i see VLAN access:1 which is wierd.
I do show interface virtual and i see nothing on the Nexus
The uplinks on the Nexus VDS are up though
~ # vemcmd show port
  LTL   VSM Port  Admin Link  State    Cause  PC-LTL  SGID  ORG  svcpath  Type          Vem Port
   19     Eth1/2     UP   UP    F/B*       -       0          0        0                vmnic1
   20     Eth1/3     UP   UP    F/B*       -       0          0        0                vmnic2
   51              DOWN   UP    BLK      none      0          0        0                Nexus1000V-5.2.1.SV3.3.15.eth4
   52              DOWN   UP    BLK      none      0          0        0                Nexus1000V-5.2.1.SV3.3.15.eth3
Can someone help out here thanks .
0 Replies 0
