Nexus 1000v VEM module bouncing between hosts
netdood
Level 3
Level 3
I'm receiving these error messages on my N1KV and don't know how to fix it.  I've tried removing, rebooting, reinstalling host B's VEM but that did not fix the issue.  How do I debug this?
My setup,
Two physical hosts running esxi 5.1, vcenter appliance, n1kv with two system uplinks and two uplinks for iscsi for each host.  Let me know if you need more output from logs or commands, thanks.
N1KV# 2013 Jun 17 18:18:07 N1KV %VEM_MGR-2-VEM_MGR_DETECTED: Host 192.168.52.100 detected as module 3
2013 Jun 17 18:18:07 N1KV %VEM_MGR-2-MOD_ONLINE: Module 3 is online
2013 Jun 17 18:18:08 N1KV %VEM_MGR-2-VEM_MGR_REMOVE_UNEXP_NODEID_REQ: Removing VEM 3 (Unexpected Node Id Request)
2013 Jun 17 18:18:09 N1KV %VEM_MGR-2-MOD_OFFLINE: Module 3 is offline
2013 Jun 17 18:18:13 N1KV %VEM_MGR-2-VEM_MGR_DETECTED: Host 192.168.51.100 detected as module 3
2013 Jun 17 18:18:13 N1KV %VEM_MGR-2-MOD_ONLINE: Module 3 is online
2013 Jun 17 18:18:16 N1KV %VEM_MGR-2-VEM_MGR_REMOVE_UNEXP_NODEID_REQ: Removing VEM 3 (Unexpected Node Id Request)
2013 Jun 17 18:18:17 N1KV %VEM_MGR-2-MOD_OFFLINE: Module 3 is offline
2013 Jun 17 18:18:21 N1KV %VEM_MGR-2-VEM_MGR_DETECTED: Host 192.168.52.100 detected as module 3
2013 Jun 17 18:18:21 N1KV %VEM_MGR-2-MOD_ONLINE: Module 3 is online
2013 Jun 17 18:18:22 N1KV %VEM_MGR-2-VEM_MGR_REMOVE_UNEXP_NODEID_REQ: Removing VEM 3 (Unexpected Node Id Request)
2013 Jun 17 18:18:23 N1KV %VEM_MGR-2-MOD_OFFLINE: Module 3 is offline
2013 Jun 17 18:18:28 N1KV %VEM_MGR-2-VEM_MGR_DETECTED: Host 192.168.51.100 detected as module 3
2013 Jun 17 18:18:29 N1KV %VEM_MGR-2-MOD_ONLINE: Module 3 is online
2013 Jun 17 18:18:44 N1KV %PLATFORM-2-MOD_DETECT: Module 2 detected (Serial number :unavailable) Module-Type Virtual Supervisor Module Model :unavailable
N1KV# sh module
Mod  Ports  Module-Type                       Model               Status
1    0      Virtual Supervisor Module         Nexus1000V          ha-standby
2    0      Virtual Supervisor Module         Nexus1000V          active *
3    248    Virtual Ethernet Module           NA                  ok
Mod  Sw                  Hw
1    4.2(1)SV2(1.1a)     0.0
2    4.2(1)SV2(1.1a)     0.0
3    4.2(1)SV2(1.1a)     VMware ESXi 5.1.0 Releasebuild-838463 (3.1)
Mod  MAC-Address(es)                         Serial-Num
1    00-19-07-6c-5a-a8 to 00-19-07-6c-62-a8  NA
2    00-19-07-6c-5a-a8 to 00-19-07-6c-62-a8  NA
3    02-00-0c-00-03-00 to 02-00-0c-00-03-80  NA
Mod  Server-IP        Server-UUID                           Server-Name
1    192.168.54.2     NA                                    NA
2    192.168.54.2     NA                                    NA
3    192.168.51.100   03000200-0400-0500-0006-000700080009  NA
* this terminal session
~ # vemcmd show card
Card UUID type  2: 03000200-0400-0500-0006-000700080009
Card name:
Switch name: N1KV
Switch alias: DvsPortset-1
Switch uuid: e6 dc 36 50 c0 a9 d9 a5-0b 98 fb 90 e1 fc 99 af
Card domain: 2
Card slot: 3
VEM Tunnel Mode: L3 Mode
L3 Ctrl Index: 49
L3 Ctrl VLAN: 51
VEM Control (AIPC) MAC: 00:02:3d:10:02:02
VEM Packet (Inband) MAC: 00:02:3d:20:02:02
VEM Control Agent (DPA) MAC: 00:02:3d:40:02:02
VEM SPAN MAC: 00:02:3d:30:02:02
Primary VSM MAC : 00:50:56:b6:0c:b2
Primary VSM PKT MAC : 00:50:56:b6:35:3f
Primary VSM MGMT MAC : 00:50:56:b6:d5:12
Standby VSM CTRL MAC : 00:50:56:b6:96:f2
Management IPv4 address: 192.168.51.100
Management IPv6 address: 0000:0000:0000:0000:0000:0000:0000:0000
Primary L3 Control IPv4 address: 192.168.54.2
Secondary VSM MAC : 00:00:00:00:00:00
Secondary L3 Control IPv4 address: 0.0.0.0
Upgrade : Default
Max physical ports: 32
Max virtual ports: 216
Card control VLAN: 1
Card packet VLAN: 1
Control type multicast: No
Card Headless Mode : No
       Processors: 4
  Processor Cores: 4
Processor Sockets: 1
  Kernel Memory:   16669760
Port link-up delay: 5s
Global UUFB: DISABLED
Heartbeat Set: True
PC LB Algo: source-mac
Datapath portset event in progress : no
Licensed: Yes
Card name:
Switch name: N1KV
Switch alias: DvsPortset-0
Card domain: 2
Card slot: 3
L3 Ctrl Index: 49
L3 Ctrl VLAN: 52
Management IPv4 address: 192.168.52.100
Upgrade : Default
Card packet VLAN: 1
Card Headless Mode : Yes
       Processors: 4
  Processor Cores: 4
  Kernel Memory:   16669764
Heartbeat Set: False
Licensed: Yes
! ports 1-6 connected to physical host A
interface GigabitEthernet1/0/1
description VMWARE ESXi Trunk
switchport mode trunk
switchport nonegotiate
spanning-tree portfast trunk
spanning-tree bpdufilter enable
spanning-tree bpduguard enable
channel-group 1 mode active
! ports 7-12 connected to phys host B
interface GigabitEthernet1/0/7
channel-group 2 mode active
11 Replies 11
sprasath
Level 7
Level 7
Hi Tim,
- How/when did you land in this situation?
- You've mentioned two hosts running ESX 5.1, but there is only one present here.
    - Is the other added to the N1k?
- Get the following from the VSM:
    - show vms internal info dvs
    - show svs neighbors
Shankar
Hi Shankar,
The two vemcmds are from two different hosts, you can see the switch alias and L3 control vlan are slightly different.  A lot of the other information is the same.
I deleted both N1KV vm's and uninstalled the VEMs.  I'm trying to reinstall again.  I'll reply here if I run into it again.
Hi Tim,
The L3 control VLAN depends on what you chose in the port-profile that you assign to your L3-capable vmknic. I didn't realise that they're from two different hosts. The UUID is the same and that is the reason for the error in your case.
You need to make sure that the UUID is different.
Shankar
ok after deleteing the n1kv vms and vcenter and then reinstalling all I got the error again,
N1KV# 2013 Jun 18 17:48:12 N1KV %VEM_MGR-2-VEM_MGR_REMOVE_STATE_CONFLICT: Removing VEM 3 due to state conflict VSM(NodeId Processed), VEM(ModIns End Rcvd)
2013 Jun 18 17:48:13 N1KV %VEM_MGR-2-MOD_OFFLINE: Module 3 is offline
2013 Jun 18 17:48:16 N1KV %VEM_MGR-2-VEM_MGR_DETECTED: Host 192.168.52.100 detected as module 3
2013 Jun 18 17:48:16 N1KV %VEM_MGR-2-MOD_ONLINE: Module 3 is online
2013 Jun 18 17:48:22 N1KV %VEM_MGR-2-VEM_MGR_REMOVE_STATE_CONFLICT: Removing VEM 3 due to state conflict VSM(NodeId Processed), VEM(ModIns End Rcvd)
2013 Jun 18 17:48:23 N1KV %VEM_MGR-2-MOD_OFFLINE: Module 3 is offline
2013 Jun 18 17:48:34 N1KV %VEM_MGR-2-VEM_MGR_DETECTED: Host 192.168.52.100 detected as module 3
2013 Jun 18 17:48:34 N1KV %VEM_MGR-2-MOD_ONLINE: Module 3 is online
2013 Jun 18 17:48:41 N1KV %VEM_MGR-2-VEM_MGR_REMOVE_STATE_CONFLICT: Removing VEM 3 due to state conflict VSM(NodeId Processed), VEM(ModIns End Rcvd)
2013 Jun 18 17:48:42 N1KV %VEM_MGR-2-MOD_OFFLINE: Module 3 is offline
2013 Jun 18 17:49:03 N1KV %VEM_MGR-2-VEM_MGR_DETECTED: Host 192.168.52.100 detected as module 3
2013 Jun 18 17:49:03 N1KV %VEM_MGR-2-MOD_ONLINE: Module 3 is online
2013 Jun 18 17:49:10 N1KV %VEM_MGR-2-VEM_MGR_REMOVE_STATE_CONFLICT: Removing VEM 3 due to state conflict VSM(NodeId Processed), VEM(ModIns End Rcvd)
2013 Jun 18 17:49:11 N1KV %VEM_MGR-2-MOD_OFFLINE: Module 3 is offline
2013 Jun 18 17:49:29 N1KV %VEM_MGR-2-VEM_MGR_DETECTED: Host 192.168.51.100 detected as module 3
2013 Jun 18 17:49:29 N1KV %VEM_MGR-2-MOD_ONLINE: Module 3 is online
2013 Jun 18 17:49:35 N1KV %VEM_MGR-2-VEM_MGR_REMOVE_STATE_CONFLICT: Removing VEM 3 due to state conflict VSM(NodeId Processed), VEM(ModIns End Rcvd)
2013 Jun 18 17:49:36 N1KV %VEM_MGR-2-MOD_OFFLINE: Module 3 is offline
2013 Jun 18 17:49:53 N1KV %VEM_MGR-2-VEM_MGR_DETECTED: Host 192.168.51.100 detected as module 3
2013 Jun 18 17:49:53 N1KV %VEM_MGR-2-MOD_ONLINE: Module 3 is online
2013 Jun 18 17:49:59 N1KV %VEM_MGR-2-VEM_MGR_REMOVE_STATE_CONFLICT: Removing VEM 3 due to state conflict VSM(NodeId Processed), VEM(ModIns End Rcvd)
2013 Jun 18 17:50:00 N1KV %VEM_MGR-2-MOD_OFFLINE: Module 3 is offline
2013 Jun 18 17:50:05 N1KV %VEM_MGR-2-VEM_MGR_DETECTED: Host 192.168.52.100 detected as module 3
2013 Jun 18 17:50:05 N1KV %VEM_MGR-2-MOD_ONLINE: Module 3 is online
Host A
Card name:
Switch name: N1KV
Card domain: 2
Card slot: 1
L3 Ctrl Index: 49
L3 Ctrl VLAN: 52
VEM Control (AIPC) MAC: 00:02:3d:10:02:00
VEM Packet (Inband) MAC: 00:02:3d:20:02:00
VEM Control Agent (DPA) MAC: 00:02:3d:40:02:00
VEM SPAN MAC: 00:02:3d:30:02:00
Primary VSM MAC : 00:50:56:b6:96:f2
Primary VSM PKT MAC : 00:50:56:b6:11:b6
Primary VSM MGMT MAC : 00:50:56:b6:48:c6
Standby VSM CTRL MAC : ff:ff:ff:ff:ff:ff
Upgrade : Default
Card packet VLAN: 1
       Processors: 4
  Processor Cores: 4
Licensed: No
Host B
Card name:
Switch name: N1KV
Switch uuid: bf fb 28 50 1b 26 dd ae-05 bd 4e 48 2e 37 56 f3
Card domain: 2
Card slot: 3
L3 Ctrl Index: 49
L3 Ctrl VLAN: 51
Primary VSM MAC : 00:50:56:a8:f5:f0
Primary VSM PKT MAC : 00:50:56:a8:3c:62
Primary VSM MGMT MAC : 00:50:56:a8:b4:a4
Standby VSM CTRL MAC : 00:50:56:a8:30:d5
Upgrade : Default
Card packet VLAN: 1
       Processors: 4
  Processor Cores: 4
Heartbeat Set: True
Licensed: Yes
I used the nexus 1000v java installer so I don't know what it keeps assigning the same UUID nor do I know how to change it.
Here is the other output you requested,
N1KV# show vms internal info dvs
  DVS INFO:
DVS name: [N1KV]
      UUID: [bf fb 28 50 1b 26 dd ae-05 bd 4e 48 2e 37 56 f3]
      Description: [(null)]
      Config version: [1]
      Max ports: [8192]
      DC name: [Galaxy]
     OPQ data: size [1121], data: [data-version 1.0
switch-domain 2
switch-name N1KV
cp-version 4.2(1)SV2(1.1a)
control-vlan 1
system-primary-mac 00:50:56:a8:f5:f0
active-vsm packet mac 00:50:56:a8:3c:62
active-vsm mgmt mac 00:50:56:a8:b4:a4
standby-vsm ctrl mac 0050-56a8-30d5
inband-vlan 1
svs-mode L3
l3control-ipaddr 192.168.54.2
upgrade state 0 mac 0050-56a8-30d5 l3control-ipv4 null
cntl-type-mcast 0
profile dvportgroup-26 trunk 1,51-57,110
profile dvportgroup-26 mtu 9000
profile dvportgroup-27 access 51
profile dvportgroup-27 mtu 1500
profile dvportgroup-27 capability l3control
profile dvportgroup-28 access 52
profile dvportgroup-28 mtu 1500
profile dvportgroup-28 capability l3control
profile dvportgroup-29 access 53
profile dvportgroup-29 mtu 1500
profile dvportgroup-30 access 54
profile dvportgroup-30 mtu 1500
profile dvportgroup-31 access 55
profile dvportgroup-31 mtu 1500
profile dvportgroup-32 access 56
profile dvportgroup-32 mtu 1500
profile dvportgroup-34 trunk 220
profile dvportgroup-34 mtu 9000
profile dvportgroup-35 access 220
profile dvportgroup-35 mtu 1500
profile dvportgroup-35 capability iscsi-multipath
end-version 1.0
      push_opq_data flag: [1]
show svs neighbors
Active Domain ID: 2
AIPC Interface MAC: 0050-56a8-f5f0
Inband Interface MAC: 0050-56a8-3c62
Src MAC           Type   Domain-id    Node-id     Last learnt (Sec. ago)
0050-56a8-30d5     VSM         2         0201      1020.45
0002-3d40-0202     VEM         2         0302         1.33
I cannot add Host A to the N1KV it errors out with,
vDS operation failed on host 192.168.52.100, An error occurred during host configuration. got (vim.fault.PlatformConfigFault) exception
Host B (192.168.51.100) was added fine, then I moved a vmkernel to the N1KV which brought up the VEM and got the VEM flapping errors.
Tim,
N1k just picks up the UUID from the server hardware. You can check it from the ESX CLI:
esxcfg-info | grep "BIOS UUID"
What server are you using? Unless this problem is cleared, you'll not be able to add both the hosts at the same time.
Shankar
Two shuttle boxes with i5 cpu.
192.168.51.100 shuttle
~ # esxcfg-info | grep "BIOS UUID"
      |----BIOS UUID................................................0x3 0x0 0x2 0x0 0x4 0x0 0x5 0x0 0x0 0x6 0x0 0x7 0x0 0x8 0x0 0x9
            |----World Command Line.................................grep BIOS UUID
192.168.52.100 shuttle
The UUID looks exactly the same.  Definitely two different physical boxes.
I've found a manual fix, though I think it's an installation issue/bug.  If the hardware is not vmware approved it seems to use a generic uuid of 03000200-0400-0500-0006-000700080009.
Here is the vmware doc about generic uuid problems,
http://kb.vmware.com/selfservice/microsites/search.do?language=en_US&cmd=displayKC&externalId=1006250
UUID from unrecognized hardware vendor approved list for esxi
https://communities.cisco.com/message/10271
So I manually changed the uuid on one of my esxi hosts
Check the uuid of the esxi host by going to https://YOUR_ESXI_HOST_IP/mob/?moid=ha-host&doPath=hardware%2esystemInfo
Or this command,
Card name:
Switch name: N1KV
Switch uuid: 12 93 1d 50 54 e8 53 1d-65 20 91 82 12 5f 53 79
Card domain: 2
Card slot: 3
L3 Ctrl Index: 49
L3 Ctrl VLAN: 52
Primary VSM MAC : 00:50:56:9d:ee:3f
Primary VSM PKT MAC : 00:50:56:9d:d8:08
Primary VSM MGMT MAC : 00:50:56:9d:cd:cf
Standby VSM CTRL MAC : 00:50:56:9d:18:18
Upgrade : Default
Card packet VLAN: 1
       Processors: 4
  Processor Cores: 4
Heartbeat Set: True
Licensed: Yes
ENTER THIS COMMAND ON PHYSICAL ESXi server
~ # vemcmd card uuid vmware 03000200-0400-0500-0006-000700080099
Card UUID type  2: 03000200-0400-0500-0006-000700080099
Card name:
Switch name: N1KV
Card domain: 2
Card slot: 4
L3 Ctrl Index: 49
L3 Ctrl VLAN: 52
VEM Control (AIPC) MAC: 00:02:3d:10:02:03
VEM Packet (Inband) MAC: 00:02:3d:20:02:03
VEM Control Agent (DPA) MAC: 00:02:3d:40:02:03
VEM SPAN MAC: 00:02:3d:30:02:03
Upgrade : Default
Card packet VLAN: 1
       Processors: 4
  Processor Cores: 4
Heartbeat Set: True
Licensed: Yes
confirm by show run,
hostname N1KV
errdisable recovery cause failed-port-state
vem 3
  host vmware id 03000200-0400-0500-0006-000700080009
vem 4
  host vmware id 03000200-0400-0500-0006-000700080099
and show module,
N1KV(config)# sh module
1    0      Virtual Supervisor Module         Nexus1000V          active *
2    0      Virtual Supervisor Module         Nexus1000V          ha-standby
4    248    Virtual Ethernet Module           NA                  ok
Mod  Sw                  Hw
4    4.2(1)SV2(1.1a)     VMware ESXi 5.1.0 Releasebuild-838463 (3.1)
4    02-00-0c-00-04-00 to 02-00-0c-00-04-80  NA
3    192.168.51.100   03000200-0400-0500-0006-000700080009  192.168.51.100
4    192.168.52.100   03000200-0400-0500-0006-000700080099  NA
Ok. N1k and ESX take the UUID from the BIOS. I don't think it is a bug. It is similar to the 169.. address that you get when a NIC in Windows does not get an IP address from DHCP.
Either way, did you have to reload the server? And what is the UUID reported at the ESX level (
esxcfg-info | grep "BIOS UUID")
Shankar
No I did not have to reload the server to get n1kv to recognize the different uuid.
If you are referring to after the manual UUID change, the UUID is still the same at the ESXi level,
Host A
Host B
Well the UUID did not survive a reboot.  I tried modify vssnet-functions but there is some weird permissions plus overwriting or restoring that I don't understand with that whole directory.
In vssnet-functions you can try to manually have it set the UUID,
https://supportforums.cisco.com/thread/2166139
#Usage: setBiosUuid
# Gets the hosts's BIOS UUID and sets the card UUID
setBiosUuid()
        local UUID
#       UUID=$(esxcfg-info -u | awk '{print tolower($1)}')
### vemcmd card uuid vmware 03000200-0400-0500-0006-000700080099
UUID="03000200-0400-0500-0006-000700080099"
        if [ "${UUID}" != "" ] ; then
                doCommand ${VEMCMD} card uuid vmware ${UUID}
        fi
#Usage: setServerUuid
# Set the card UUID to the Host's Server UUID
setServerUuid()
        local UUID
        UUID=$(grep '^/system/uuid' ${VMWARECONF} | \
                        sed -e 's/^.* = "//' -e 's/".*$//')
        fi
It would not let me write changes to vssnet-functions even if I put 777 permissions on the file.  I was able to copy that file to another, make my edits and then copy it back to the original file but those changes didn't survive a reboot and the system mysteriously reverts the changes, deletes my copy of the file, and sets the permissions back to the original.
/opt/cisco/v152/nexus/vem-v152/shell # ls
vem-install-functions  vem-preuninstall       vssnet-functions
vem-postinstall        vsi-functions          vssnet-functions.orig
/opt/cisco/v152/nexus/vem-v152/shell # ll
-sh: ll: not found
/opt/cisco/v152/nexus/vem-v152/shell # ls -all
drwxr-xr-x    1 root     root           512 Jun 20 18:20 .
drwxr-xr-x    1 root     root           512 Jun 20 17:59 ..
-r-xr--r--    1 root     root          3428 Jan 21 10:26 vem-install-functions
-r-xr--r--    1 root     root           718 Jan 21 10:26 vem-postinstall
-r-xr--r--    1 root     root          1001 Jan 21 10:26 vem-preuninstall
-r-xr--r--    1 root     root         36517 Jan 21 10:26 vsi-functions
-rwxrwxrwx    1 root     root         40529 Jan 21 10:26 vssnet-functions
-rwxr-xr-x    1 root     root         40575 Jun 20 18:28 vssnet-functions.orig
/opt/cisco/v152/nexus/vem-v152/shell # cp vssnet-functions.orig vssnet-functions
/opt/cisco/v152/nexus/vem-v152/shell # chmod 644 vssnet-functions
/opt/cisco/v152/nexus/vem-v152/shell # chmod 644 vssnet-functions.orig
/opt/cisco/v152/nexus/vem-v152/shell # reboot
Now directory is cleaned out
drwxr-xr-x    1 root     root           512 Jun 20 18:39 .
drwxr-xr-x    1 root     root           512 Jun 20 18:39 ..
-r-xr--r--    1 root     root         40529 Jan 21 10:26 vssnet-functions
Hi Tim,
What you're doing is not recommended/supported. You should look at changing the UUID using a proper procedure, if any, from the hardware perspective.
Changing it from the Nexus 1000v level (using vemcmd, vssnet) are only temporary workarounds, as you've seen.
Shankar
