Nexus 4001i no fip MACs showing
ArrowSIVAC
Environment:
IBM BCH blade in bay 12 with QLogic 10Gb Convergence adapter.
CISCO Nexus 5010 (sw10) ports 3, 4 trunked via port group to BCH Chassis bay 7 ports 15, 16 port group.
First time setting this up. Following the examples guide for the 4001i and 5010 as well as the read the admin guide.
Issue: It seems I have everything setup. I simply need to see the WWPN show up in the fabric so I can map it through to the Fibre Storage devices, but when I run "show fip-snooping vlan-discovery"  no MACs show.  I manually went into the blade managment module, recorded the MAC and built the vrf table entry, but not working, so I beleive something is missconfigured. Need some guidance... clue I beleive is that no MAC shows up in the FIP query.
Current Configuration (I tried to cut it down to just things related to pertinent data)
Nexus 5010
Nexus 4001i
feature fcoe
feature npiv
feature telnet
feature lacp
feature lldp
feature fex
class-map type qos class-fcoe
class-map type queuing class-all-flood
  match qos-group 2
class-map type queuing class-ip-multicast
  match qos-group 2
class-map type network-qos class-all-flood
  match qos-group 2
class-map type network-qos class-ip-multicast
  match qos-group 2
vlan 11
  name serverdata
vlan 28
  fcoe vsan 28
  name vsan
vsan database
  vsan 28 name "vsan"
fcdomain domain 29 static vsan 28
interface port-channel11
  description sw10-03_04 to sw14-15_16
  switchport mode trunk
  switchport trunk native vlan 11
  speed 10000
interface vfc112
  bind mac-address 00:c0:dd:17:8e:10
  switchport description bch112
  no shutdown
vsan database
  vsan 28 interface vfc9
  vsan 28 interface vfc10
  vsan 28 interface vfc28
  vsan 28 interface vfc112
  vsan 28 interface fc2/1
  vsan 28 interface fc2/2
  vsan 28 interface fc2/3
  vsan 28 interface fc2/4
  vsan 28 interface fc2/5
  vsan 28 interface fc2/6
  vsan 28 interface fc2/7
  vsan 28 interface fc2/8
interface fc2/1
  switchport description fc01-09-12 (E Mode Port)
  no shutdown
interface Ethernet1/3
  description sw14-15
  channel-group 11
interface Ethernet1/4
  description sw14-16
  channel-group 11
boot kickstart bootflash:/n5000-uk9-kickstart.5.0.2.N2.1.bin
boot system bootflash:/n5000-uk9.5.0.2.N2.1.bin
feature telnet
feature lacp
feature fip-snooping
policy-map type queuing policy-fcoe-bandwidth
  class type queuing 1p7q4t-out-q-default
    bandwidth percent 50
  class type queuing 1p7q4t-out-pq1
    bandwidth percent 7
  class type queuing 1p7q4t-out-q2
    bandwidth percent 7
  class type queuing 1p7q4t-out-q3
    bandwidth percent 7
  class type queuing 1p7q4t-out-q4
    bandwidth percent 7
  class type queuing 1p7q4t-out-q5
    bandwidth percent 7
  class type queuing 1p7q4t-out-q6
    bandwidth percent 7
  class type queuing 1p7q4t-out-q7
    bandwidth percent 7
class-map type network-qos class-fcoe
  match cos 3
class-map type network-qos class-non-fcoe
  match cos 0-2,4-7
policy-map type network-qos policy-fcoe
  class type network-qos class-fcoe
    pause no-drop
    mtu 2500
  class type network-qos class-non-fcoe
system qos
  service-policy type network-qos policy-fcoe
  service-policy type queuing output policy-fcoe-bandwidth
vlan 11
  name serverdata
vlan 28
  fip-snooping enable
  fip-snooping fc-map 0x0efc00
  name vsan
port-channel load-balance ethernet source-dest-mac
  spanning-tree port type edge trunk
  speed 10000
interface Ethernet1/12
  description bch112
  fip-snooping port-mode fcf
  speed 10000
interface Ethernet1/15
  description sw10-03
  speed 10000
  channel-group 1
interface Ethernet1/16
  description sw10-04
  speed 10000
  channel-group 1
boot kickstart bootflash:/n4000-bk9-kickstart.4.1.2.E1.1d.bin
boot system bootflash:/n4000-bk9.4.1.2.E1.1d.bin
sw10# show license usage
Feature                      Ins  Lic   Status Expiry Date Comments
                                 Count
FM_SERVER_PKG                 No    -   Unused             -
ENTERPRISE_PKG                Yes   -   Unused Never       -
FC_FEATURES_PKG               Yes   -   In use Never       -
sw10# sh int po 11
port-channel11 is up
sw10# show vsan membership
vsan 1 interfaces:
vsan 28 interfaces:
    fc2/1             fc2/2             fc2/3             fc2/4
    fc2/5             fc2/6             fc2/7             fc2/8
    vfc9              vfc10             vfc28             vfc112
sw10# show vlan fcoe
Original VLAN ID        Translated VSAN ID      Association State
      28                        28               Operational
sw14# show license usage
                                 Count
BASIC_STORAGE_SERVICES_PKG    No    -   In use             Grace 96D 1H
sw14# sh int po1
port-channel1 is up
sw14# sh port-channel summary
Group Port-       Type     Protocol  Member Ports
      Channel
1     Po1(SU)     Eth      NONE      Eth1/15(P)   Eth1/16(P)
sw14# show fip-snooping vlan-discovery
sw14# sh int e1/12
Ethernet1/12 is up
  Hardware: 1000/10000 Ethernet, address: 588d.090e.cfcd (bia 588d.090e.cfcd)
Any thoughts on what I am missing would be appreciated.
2 Accepted Solutions
Surya ARBY
Level 4
Level 4
the fip-snooping port-mode fcf command must be applied on the uplink etherchannel, not the server facing port.
Change your config and reboot.
your config is wrong. The nexus 4000 has to know where to forward FIP messages, and the command is applied on the wrong interface
7 Replies 7
Surya ARBY
Level 4
Level 4
No details on whichever interface I try to query.
sw14# show fip-snooping vlan-discovery interface ?
  ethernet      Ethernet IEEE 802.3z
  port-channel  Port Channel interface
sw14# show fip-snooping vlan-discovery interface port-channel 1
sw14# show fip-snooping vlan-discovery interface ethernet 1/12
sw14#
Is this some kind of real time query in that the adapter must have an active kernel / driver sending out packets. I booted the server which rotates through the PXE boot mode which would (I A$$ume) accomolish this.
Thanks for the response but If you could provide some better guidance as to the correct command and where my following of the configuation guide was not correct:
http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&ved=0CCcQFjAA&url=http%3A%2F%2Fwww.cisco.com%2Fen%2FUS%2Fdocs%2Fswitches%2Fdatacenter%2Fnexus5000%2Fsw%2Foperations%2Fn5k_fcoe_ops_appD.pdf&ei=lLDgTqCJC4eYgwfSsJzwBQ&usg=AFQjCNEBzTVhhD01t...
(page 8) Enable FIP Snooping on the Port channel on the 4000 for link between the 4000 and 5000
  speed 10000
I was missing this and now when I run
  Legend:
      Interface      VLAN          FIP MAC
      Eth1/2         1         00:c0:dd:17:8d:f1
I see fip mac.... but not the slot 12 like I had defined. I will have to review this again to see what I am missing.
Issue a shut / no shut on the interface 1/12 ? Do you see LLDP negociation correctly ?
The issue was that my host facing port configuation was incorrect:
Incorrect:
  description bch112
  speed 10000
Once I changed it to:
  description bch112
  speed 10000
then the fip snooping started showing devicse
  Legend:
      Eth1/14        11        00:c0:dd:17:90:5d
      Eth1/12        11        00:c0:dd:17:8e:11
Now I added the binding to the vfc interface on the 5k...
interface vfc102
  bind mac-address 00:c0:dd:17:8d:f1
  switchport description bch102
  no shutdown
interface vfc112
  bind mac-address 00:c0:dd:17:8e:11
  no shutdown
interface vfc114
  bind mac-address 00:c0:dd:17:90:5d
  switchport description bch114
  no shutdown
Make sure the vfc are in the VSAN:
sw10# conf t
Enter configuration commands, one per line.  End with CNTL/Z.
sw10(config)# vsan database
sw10(config)# show vsan membership
vsan 1 interfaces:
vsan 28 interfaces:
    vfc9              vfc10             vfc102            vfc112
    vfc113            vfc114
(Redbook and CISCO guide shows that I should be done here and the adapters show up in MDS Manager)
Now that the interfaces are present in the VSAN I would "assume" they  would show up in fabric manager.. but they do not. I go into BIOS for  QLogic (ctrl+Q) and tell it to scan the SAN, but the device still do not  show.
I think something is wrong with the VSAN binding..
sw10# sh interface vfc114
vfc114 is trunking (Not all VSANs UP on the trunk)
    Bound MAC is 00:c0:dd:17:90:5d
    Port description is bch114
    Hardware is Virtual Fibre Channel
    Port WWN is 20:71:00:05:9b:21:60:bf
    Admin port mode is F, trunk mode is on
    snmp link state traps are enabled
sw10# sh interface port-channel 11
  Hardware: Port-Channel, address: 0005.9b21.608a (bia 0005.9b21.608a)
  Description: sw10-03_04 to sw14-15_16
  MTU 1500 bytes, BW 20000000 Kbit, DLY 10 usec,
  Encapsulation ARPA
  Port mode is trunk
  full-duplex, 10 Gb/s
  Beacon is turned off
  Input flow-control is off, output flow-control is off
  Switchport monitor is off
  EtherType is 0x8100
  Members in this channel: Eth1/3, Eth1/4
  30 seconds input rate 48 bits/sec, 6 bytes/sec, 0 packets/sec
  30 seconds output rate 173032 bits/sec, 21629 bytes/sec, 73 packets/sec
  Load-Interval #2: 5 minute (300 seconds)
    input rate 112 bps, 0 pps; output rate 91.87 Kbps, 31 pps
VSAN 28 shows status as "active" and oper state of "up"
I am not sure about the "Inorder Delivery".  No details on this and when I tried no change seems to have been made.
You have been very helpful and it is appreciated.  Any thought would be of help
Is there anything not working now ? Everything seems to be good to me.
