11-21-2012 11:10 AM
We have installed nexus 5k - (N5K-C5010P-BF) with software - 4.2(1)N1(1)
I need to buy a new Nexus 2k.
Can you tell me if N2K-C2248TF are compatible with nexus (N5K-C5010P-BF) with software - 4.2(1)N1(1)
Solved! Go to Solution.
11-21-2012 12:50 PM
I don't think there's a model called "N2K-C2248TF". Maybe N2K-C2248TP?
If this is the case, then go through the Release Notes and look under Hardware Supported. It'll tell you what NX OS your 5010 should be running to be able to support the N2K-C2248TP-1GE/N2K-C2248TP-E-1GE.
And in your case, the minimum NX-OS is 5.1(3)N1(1).
11-21-2012 02:31 PM
I just need to be 100% sure.
Raise a TAC Case for more definitive answer.
11-21-2012 12:50 PM
11-21-2012 01:38 PM
HI leolaohoo,
You are right, my N2 is N2K-C2248TP-1GE. I cannot change N5K-C5010P-BF software. I need to use 4.2(1)N1(1)
I have found more information in datasheet in Table 3. Cisco Nexus 2000 Series Gigabit Ethernet Fabric Extenders Product Specifications - Minimum Software - Cisco NX-OS Release 4.2 (Nexus 5000 Series)
http://www.cisco.com/en/US/prod/collateral/switches/ps9441/ps10110/data_sheet_c78-507093.html
And I found information in Release Notes for 4.2(1)N1(1)
•Support for the Cisco Nexus 2232 and the Cisco Nexus 2248
But i cannot find information about 4.2(1)N1(1) and N2K-C2248TP-1GE
11-21-2012 02:31 PM
