Nexus 5020 and unsupported Twinax 10 Gig cables
robert.brown
Hello
Has anyone had the oppotunity to implement a 10 Gig Twinax cable that showed up as unsupported in the logs. I have been told it is an option to use another vendors twinax, but you have to run some command in the nx-os to turn on the port with an unsupported cable/sfp.
RB
dmcloon
'service unsupported-transceiver'
Naturally if you experience a problem with that cable I doubt Cisco will support you. Good luck.
a12288
Level 3
Level 3
it's only couple of hundred bucks, why bother?
