06-20-2014 05:46 AM
Was wondering has anyone had any experience with configuring a port-channel going back to ESXi host. My basic config is below. My issue is with what to put in the spanning-tree port type. Do I use normal, edge, network, or edge trunk?? Yes I have read most of the documentation out there but am just a lil confused. I just wanna be right.
Also if anyone has any suggestions for the Vswitch config as well that would be much appreciated.
int PO 201
desc 01_6-1
switchport mode trunk
switchport access vlan 99
switchport trunk native vlan 777
switchport trunk allowed vlan 220,300,310,320-321,350,390-391
switchport trunk allowed vlan add 420,777
spanning-tree port type normal (what should go here)
speed auto
medium p2p
no shutdown
int e8/11
desc 01_6-1
channel-group 201 force
int e10/11
desc 01_6-1
Thanks Guys
06-20-2014 06:05 AM
It should be " Spanning-tree port type edge trunk "
If you are doing a port-channel to ESX, I would put the mode "ON".
06-20-2014 06:23 AM
Sam and Amit,
Can I make the change without causeing an outage?
Also does anyone have V-switch config
06-20-2014 06:53 AM
Well, if you change the spanning port type, there will be a slight disruption but port will transition to forwarding immediately so you could have a few pings timeout. This will be fairly quick though.
There is no specific V-switch config that someone can provide. I dont know that process. As far as you have the uplink ports defined and your VM's connect to the " port-group", that all should work fine.
06-20-2014 06:18 AM
Short answer: You could use spanning tree port type edge (trunk; if it's going to be a trunk). The vswitch isn't really a switch, it doesn't participate in spanning tree, so it's fine to make it an edge port.
In my experience, many VMware guys don't like port channels as much as the other more host-centric NIC teaming methods. I think this has to do with ESX having a less than stellar implementation of etherchannel/LACP early on.
06-21-2014 08:55 PM
Have you seen this doc already? I know the Cisco example is for Catalyst, but the ESXi config should apply.
