HI,
I have one Nexus 7K switch in that Module N7K-F248XP-25 showing powerdown. Please find the details for below:-
Mod Ports Module-Type Model Status
1 0 Supervisor module-1X N7K-SUP1 active *
3 48 1/10 Gbps Ethernet Module N7K-F248XP-25 ok
4 48 1/10 Gbps Ethernet Module N7K-F248XP-25 powered-dn
5 48 10/100/1000 Mbps Ethernet XL Module N7K-M148GT-11L ok
Mod Power-Status Reason
4 powered-dn Reset (powered-down) because module does not boot
Mod Sw Hw
1 6.0(2) 2.1
3 6.0(2) 1.0
5 6.0(2) 1.2
Loggs:----------------------
Aug 17 19:51:05 L3_PUNE-T2DC-DC6-N7K2-51-SERVERS %ETHPORT-5-IF_DOWN_INTERFACE_REMOVED: Interface Ethernet4/8 is down (Interface
removed)
2012 Aug 17 19:51:05 L3_PUNE-T2DC-DC6-N7K2-51-SERVERS %ETHPORT-5-IF_DOWN_INTERFACE_REMOVED: Interface Ethernet4/48 is down (Interfac
e removed)
2012 Aug 17 19:51:05 L3_PUNE-T2DC-DC6-N7K2-51-SERVERS %ETHPORT-5-IF_DOWN_MODULE_REMOVED: Interface Ethernet4/5 is down (module remov
ed)
2012 Aug 17 19:51:05 L3_PUNE-T2DC-DC6-N7K2-51-SERVERS %ETH_PORT_CHANNEL-5-PORT_DOWN: port-channel51: Ethernet4/6 is down
2012 Aug 17 19:51:05 L3_PUNE-T2DC-DC6-N7K2-51-SERVERS %ETHPORT-5-IF_DOWN_MODULE_REMOVED: Interface Ethernet4/2 is down (module remov
ed)
2012 Aug 17 19:51:05 L3_PUNE-T2DC-DC6-N7K2-51-SERVERS %ETHPORT-5-IF_DOWN_MODULE_REMOVED: Interface Ethernet4/6 is down (module remov
ed)
2012 Aug 17 19:51:05 L3_PUNE-T2DC-DC6-N7K2-51-SERVERS %ETHPORT-5-IF_DOWN_INTERFACE_REMOVED: Interface Ethernet4/1 is down (Interface
removed)
Kindly let me know what is the issue with the Module.
You should contact TAC. This looks like hardware issue to me.
jerry
Make sure you have module 4 is in same VDC as module 3 or in its own dedicated F2 only VDC.
If so you can collect show tech module 4 and open a case.
I don't think that is a configuration issue. This is definitely hardware related.
jerry
Duplicate post #2.
Did you ever find a fix for this or did Cisco RMA it? I've having the same issue with an F2E card.
I am having this same issue. Except it looks like there is an ASIC failure.
2015 Jul 22 20:35:47 sungard-n7sw1 %PLATFORM-2-PFM_MODULE_POWER_ON: Manual power-on of Module 1
from Command Line Interface
2015 Jul 22 20:35:47 sungard-n7sw1 %PLATFORM-2-MOD_DETECT: Module 1 detected (Serial number JAF17
43AKAK) Module-Type 1/10 Gbps Ethernet Module Model N7K-F248XP-25E
2015 Jul 22 20:35:48 sungard-n7sw1 %PLATFORM-2-MOD_PWRUP: Module 1 powered up (Serial number JAF1
743AKAK)
2015 Jul 22 20:35:48 sungard-n7sw1 %PLATFORM-5-MOD_STATUS: Module 1 current-status is MOD_STATUS_
POWERED_UP
2015 Jul 22 20:35:52 sungard-n7sw1 %PLATFORM-1-PFM_ALERT: FAN_BAD: fan2
2015 Jul 22 20:36:22 sungard-n7sw1 last message repeated 2 times
2015 Jul 22 20:36:22 sungard-n7sw1 %VSHD-5-VSHD_SYSLOG_CONFIG_I: Configured from vty by e0a1700 o
n 10.34.107.102@pts/4
2015 Jul 22 20:36:22 sungard-n7sw1 %PLATFORM-1-PFM_ALERT: FAN_BAD: fan2
2015 Jul 22 20:36:46 sungard-n7sw1 last message repeated 2 times
2015 Jul 22 20:36:46 sungard-n7sw1 %BIOS_DAEMON-SLOT1-5-BIOS_DAEMON_LC_PRI_BOOT: System booted f
rom Primary BIOS Flash
2015 Jul 22 20:36:52 sungard-n7sw1 %PLATFORM-1-PFM_ALERT: FAN_BAD: fan2
2015 Jul 22 20:36:53 sungard-n7sw1 %VSHD-5-VSHD_SYSLOG_CONFIG_I: Configured from vty by admin on
vsh.14481
2015 Jul 22 20:36:54 sungard-n7sw1 %MODULE-2-MOD_DIAG_FAIL: Module 1 (Serial number: JAF1743AKAK)
reported failure on ports Ethernet1/9-12 (Ethernet) due to ASIC init failure in device DEV_CLP_L
3 (device error 0xcaf00200)
2015 Jul 22 20:36:57 sungard-n7sw1 %PLATFORM-2-MOD_DETECT: Module 1 detected (Serial number JAF17
2015 Jul 22 20:36:57 sungard-n7sw1 %PLATFORM-2-MOD_PWRUP: Module 1 powered up (Serial number JAF1
743AKAK)
2015 Jul 22 20:36:57 sungard-n7sw1 %PLATFORM-5-MOD_STATUS: Module 1 current-status is MOD_STATUS_
POWERED_UP
2015 Jul 22 20:37:02 sungard-n7sw1 %PLATFORM-1-PFM_ALERT: FAN_BAD: fan2
2015 Jul 22 20:37:43 sungard-n7sw1 last message repeated 4 times
2015 Jul 22 20:37:57 sungard-n7sw1 last message repeated 1 time
2015 Jul 22 20:37:57 sungard-n7sw1 %BIOS_DAEMON-SLOT1-5-BIOS_DAEMON_LC_PRI_BOOT: System booted f
2015 Jul 22 20:38:03 sungard-n7sw1 %PLATFORM-1-PFM_ALERT: FAN_BAD: fan2
2015 Jul 22 20:38:03 sungard-n7sw1 %MODULE-2-MOD_DIAG_FAIL: Module 1 (Serial number: JAF1743AKAK)
2015 Jul 22 20:38:05 sungard-n7sw1 %PLATFORM-2-MOD_DETECT: Module 1 detected (Serial number JAF17
2015 Jul 22 20:38:05 sungard-n7sw1 %PLATFORM-2-MOD_PWRUP: Module 1 powered up (Serial number JAF1
743AKAK)
2015 Jul 22 20:38:05 sungard-n7sw1 %PLATFORM-5-MOD_STATUS: Module 1 current-status is MOD_STATUS_
POWERED_UP
2015 Jul 22 20:38:13 sungard-n7sw1 %PLATFORM-1-PFM_ALERT: FAN_BAD: fan2
2015 Jul 22 20:38:53 sungard-n7sw1 last message repeated 4 times
2015 Jul 22 20:39:08 sungard-n7sw1 last message repeated 1 time
2015 Jul 22 20:39:08 sungard-n7sw1 %BIOS_DAEMON-SLOT1-5-BIOS_DAEMON_LC_PRI_BOOT: System booted f
2015 Jul 22 20:39:13 sungard-n7sw1 %PLATFORM-1-PFM_ALERT: FAN_BAD: fan2
2015 Jul 22 20:39:14 sungard-n7sw1 %MODULE-2-MOD_DIAG_FAIL: Module 1 (Serial number: JAF1743AKAK)
2015 Jul 22 20:39:14 sungard-n7sw1 %MODULE-2-MOD_FAIL: Initialization of module 1 (Serial number:
JAF1743AKAK) failed
2015 Jul 22 20:39:14 sungard-n7sw1 last message repeated 1 time
2015 Jul 22 20:39:14 sungard-n7sw1 %PLATFORM-2-MOD_PWRDN: Module 1 powered down (Serial number JA
F1743AKAK)
2015 Jul 22 20:39:14 sungard-n7sw1 %PLATFORM-5-MOD_STATUS: Module 1 current-status is MOD_STATUS_
CONFIGPOWERED_DOWN
POWERED_DOWN
