Nexus multicast rp problem
mflanigan021
Level 2
Level 2
Customer running Nexus 7000 6.03a.  Core and Distribution VDCs.  With the static RP configuration shown below,
a source in VLAN 300 attached to a L2 Catalyst 6500, and a receiver on eth 1/14 on the core, multicast traffic
in groups 234.5.6.7-234.5.6.11 is delivered successfully from source to receiver.  When we try to use anycast-rp,
replacing the staic rp config in the distribution VDC with the 2 lines below, all traffic fails.
ip pim anycast-rp 10.129.26.146 10.129.26.133     <==== Other distribution VDC loopback 100 IP
ip pim anycast-rp 10.129.26.146 10.129.26.134     <==== Local distribution VDC loopback 100 IP
Loopback 99 is the anycast RP 'virtual' address, loopback 100 is the local RP used for anycast rp-to-rp communication.
Debugging pim joins generates a message 'no rp found for group x.x.x.x' for all five groups on
the distribution VDC.  The core pim debug shows no errors.
Unicast routing (BGP and static) IP addressing is working correctly. IGMP/IGMP snooping also appears correct,
and we are seeing the groups joined on the core VDC.
I am at a loss to explain why the distribution VDC cannot recognize itself as an RP.  Does anyone have an idea?
Some additional config notes:
There are two Nexus chassis, each split into core and distributtion VDCs.  There is a VPC between the distribution VDCs,
with member vlans trunked to a pair of 6509s, operating at layer 2 only. Vlan 300, the source vlan, is a vpc member.
The source is attached to a 6509 port in Vlan 300.
Each distribution VDC has a pairof layer 3 ports, each connected to one of the core VDCs.  The core VDCs have a layer 3
link between them, and the distribution VDCs have a layer 3 link outside the vpc.  Basically, the L3 is a bow-tie,
with horizotal cross links as well.  PIM is running on all L3 links, as well on vlan 300, and the loopbacks used for RP.
Distribution VDC
ip pim rp-address 10.129.26.146 group-list 224.0.0.0/4
ip pim log-neighbor-changes
ip pim ssm range 232.0.0.0/8
interface Vlan300
  ip address 10.129.26.67/28
  ip pim sparse-mode
  ip pim dr-priority 200
  hsrp 200
    preempt
    priority 150
    ip 10.129.26.65
  ip dhcp relay address 10.129.26.84
  description Dist Server VLAN 300
  no shutdown
interface loopback99
  ip address 10.129.26.146/32
  ip pim sparse-mode
interface loopback100
  ip address 10.129.26.134/32
  ip pim sparse-mode
interface Ethernet5/1
  description cidcnxsw2-DIST to cidcnxsw2-CORE
  no switchport
  ip address 10.129.26.246/30
  ip pim sparse-mode
  no shutdown
Core VDC
interface Vlan111
  description Multicast Anycast Test VLAN
  no shutdown
  ip address 10.129.27.35/27
  ip pim sparse-mode
interface Ethernet1/14
  description Test PC
  switchport
  switchport access vlan 111
  no shutdown
interface Ethernet2/1
  description cidcnxsw2-CORE to cidcnxsw2-DIST
  ip address 10.129.26.245/30
  ip pim sparse-mode
  no shutdown
Marcel Zehnder
If you configure anycast-RP you still need the config-line for the static-rp. So you need these 3 lines on your anycast-rp-routers:
Line 1 & 2 providing the anycast RP (you configure a redundant RP) - but you still need the third line to tell your routers where they find the RP.
Marcel
Marcel Zehnder
Marcel
Marcel,
Thanks - that makes sense.  We still need to do full testing, but I think this will addressw the issue.
Glad I could help. Have a nice day
