Nexus Nexus7700 C7706 Json output
kevin_1234
Today I tried to do some testing with automation on the Nexus 7700 with Ansible. The Ansible Modules for nxos wants it output in Json format.
So Ansible adds ad the end of every command "| json". The Nexus should support this. But I always get the error, that Python cannot load the modul xmltodict.
Even If try for example the command directly on the cli "show version | json" I get the same, like with ansible, error:
XX# show version | json
Traceback (most recent call last):
File "/isan/python/scripts/pipejson.py", line 3, in <module>
import os, sys, shlex, json, xmltodict, re, fnmatch
ImportError: No module named xmltodict
Does someone had the same problem, or have some ideas?
Thanks and cheers, Kevin
BIOS: version 3.1.0
kickstart: version 7.2(0)D1(1)
system: version 7.2(0)D1(1)
kevin_1234
The new version  7.2(2)D1(2) fixed this issue.
kevin_1234
Sean.Cavanaugh
In case you are on an older version of NXOS, the nxos_facts module is great at this.  I have a playbook here: https://github.com/network-automation/ansible-napalm-samples/blob/master/showversion.yml
- hosts: cisco
  connection: local
  gather_facts: False
  tasks:
    - name: run show version
      nxos_facts:
        provider: "{{login_info}}"
    - debug:
        var: ansible_net_version
Hi Tanks for your reply!
can you make "show version | json "
it looks like in my version they forgot to place the python modul (xmltodict.py) in /isan/python/scipts/.
But I find nowhere any changelog about this issue.
Do you know can I somehow place files in this locations?
Cheers, Kevin
ah I see you are using n9k ;)
