Nexus1000v connection
davidcheung
Level 3
Level 3
When i issue command: show svs con
I can see vmware-vim is running over https. Anybody can give a brief explaination abour remote-port 80 means in the output?
1000v# show svs conn
connection sp400:
    ip address: 10.250.250.101
    remote port: 80
    protocol: vmware-vim https
    certificate: default
    datacenter name: vCentre
    DVS uuid: xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
    config status: Enabled
    operational status: Connected
    sync status: Complete
    version: VMware vCenter Server 4.1.0 build-345043
mipetrin
Hi David,
The remote port is used to configure the remote host TCP port that is used for the initial connection to vCenter using HTTP. This is by default set to port 80, unless you have changed this setting within vCenter in which case you would need to modify this setting.
Michael
