NTP issues on Nexus C7706
Read articles all over about ntp and vdcs, but cant seem to figure it out.
N7706-01-CORE(config)# ntp commit
Fabric Distribution not enabled for NTP
N7706-01-CORE(config)# show run | inc ntp
ntp server 172.24.0.202
ntp server 172.24.254.9 prefer use-vrf default
ntp source-interface loopback1
N7706-01-CORE(config)# show ntp ?
*** No matching command found in current mode, matching in (exec) mode ***
access-groups Display NTP access groups
authentication-keys Display authentication keys
authentication-status NTP Authentication Status
internal NTP internal info
logging-status Display NTP logging status
peer-status Show the status for all the server/peers
peers Show all the peers.
pending Show the NTP temporary database
pending-diff Show the pending database diff.
rts-update Show if the RTS update is enabled
session Show the session information
source Source IP address configured
source-interface Source interface configured
statistics Show the NTP statistics
status Show the NTP distribution status
trusted-keys Display trusted keys
N7706-01-CORE(config)# show ntp access-groups
No such entry present
N7706-01-CORE(config)# show ntp peers
INFO: System clock is not controlled by NTP in this VDC
You can use "clock protocol <protocol> vdc <vdc_id>"
to change the current setting.
N7706-01-CORE(config)# show ntp peer-status
N7706-01-CORE(config)# show vdc
Switchwide mode is f2e f3 m3
vdc_id vdc_name state mac type lc
2 CORE active 8c:60:4f:03:d0:c2 Ethernet f2e f3
N7706-01-CORE(config)# exit
N7706-01-CORE# clock protoco?
% Invalid command at '^' marker.
N7706-01-CORE# clock protoco ?
Clock protocol ntp doesnt work like articles say.
M02@rt37
Hello @Steven-Williams-83
#show ntp peer-status
#show ntp peers
You will see if your N7k is synchronised.
Best regards
as shown in my original post:
OK @Steven-Williams-83
Under config-terminal
N7706-01-CORE(config)# clock protocol ntp vdc <vdc_id>
Other thread:
https://community.cisco.com/t5/server-networking/ntp-problem-on-nexus-7000/td-p/1783123
Best regards
N7706-01-CORE(config)# no ntp server 172.24.0.202
N7706-01-CORE(config)# clock pro?
Software
BIOS: version 3.1.0
kickstart: version 7.3(4)D1(1)
system: version 7.3(4)D1(1)
