Peer-link - mixing M1 and M2 cards on the same chassis
Nuno Marques
Hi guys,
for migrations propuses i need to add 2 links from a M2 card to the peer-link port-channel already configured in a M1 card:
N7K-1     VPC Peer link    N7K-2
M2    -----------------------  M2
M1    ----------------------   M1
I cant find any documentacion for this specific cards,
we are running 6.2(8a).
Anyone can advise,
thx
regards
5 Replies 5
Hi Nunos
Do you have an answer regarding this issue , I have the same case , i'm running VPC peerlink on M1 and now i would like to had an M2 interconnection .( same design like yours )
Thanks for your feedback
Choukri
You cannot mix them, you will need to create another port-channel with the M2 module and then migrate the peer-link configuration over.
More info on this is found on the following Cisco LIVE presentation BRKDCT-2048
Yamil
InayathUlla Sharieff
No, you cannot configure the ports from an M1 and M2 series linecard in the same port
channel. This is referenced in our N7K Interfaces Configuration Guide at the following
link:
http://www.cisco.com/en/US/docs/switches/datacenter/sw/6_x/nx-os/interfaces/configuration/
guide/if_portchannel.html#wp1888267
Starting with revision 6.2, you can mix any M Series I/O modules to create a vPC peer as
illustrated in the following table.
I/O Module Combinations Supported on Both Sides of a vPC Peer Link, Cisco NX-OS Release
6.2
Config guide on the same:-
guide/if_vPC.html#wp1803465
lovsharm
This is not about the Peer-link. peer link is just a normal trunk port which VPC will use. This Limitation is because of the different parameters on the both linecards module. YOU CAN NOT BIND TWO INTERFACES IN A LOGICAL BUNDEL IF THEY ARE OF DIFFERENT PERAMETER. https://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus5000/sw/configuration/guide/cli/CLIConfigurationGuide/EtherChannel.html
Compatibility Requirements
When you add an interface to a channel group, the Cisco NX-OS checks certain interface attributes to ensure that the interface is compatible with the channel group. The Cisco NX-OS also checks a number of operational attributes for an interface before allowing that interface to participate in the port-channel aggregation.
The compatibility check includes the following operational attributes:
  • Port mode
  • Access VLAN
  • Trunk native VLAN
  • Allowed VLAN list
  • Speed
  • 802.3x flow control setting
  • MTU
This attribute is strictly not applicable as the Cisco Nexus 5000 Series switch only supports system level MTU.
  • Broadcast/Unicast/Multicast Storm Control setting
  • Priority-Flow-Control
  • Untagged CoS
Use the show port-channel compatibility-parameters command to see the full list of compatibility checks that the Cisco NX-OS uses.
Regards:
Lovkesh
