Problem Accessing FWSM From Switch Console
aafkhami
Community Member
I have a 6509 with FWSM in module 4. FWSM is configured in single context mode. After I configured passwords and authentication on the FWSM, I can no longer access the module using "session slot 4 processor 1" when connecting to the 6509 switch via console. Please note that if I ssh to 6509 then I can get to FWSM successfully.
Obviously I can remove authentication config to resolve the issue for now but I need to keep them in the final configuration and cannot figure out how they would cause the above issue to find a workaround ...
My Authentication config:
enable password ew9KHLwZJ3Ih2ff5 encrypted
passwd GQwTW2VuxBDYJJlK encrypted
username admin nopassword privilege 15
aaa authentication ssh console TACACS+ LOCAL
aaa authentication http console TACACS+ LOCAL
aaa-server TACACS+ protocol tacacs+
aaa-server TACACS+ (management) host x.x.x.x
timeout 5
key xxxxx
http server enable
http x.x.x.x 255.255.255.255 management
ssh x.x.x.x 255.255.255.255 management
telnet timeout 5
ssh timeout 5
console timeout 0
Thanks in advance for your help ...
Ali
Not applicable
The test aaa-server command lets you verify that the FWSM can authenticate users with a particular AAA server, and for legacy VPN authorization, if you can authorize a user. This command lets you test the AAA server without having an actual user who attempts to authenticate or authorize. It also helps you isolate whether AAA failures are due to misconfiguration of AAA server parameters, a connection problem to the AAA server, or other configuration errors on the FWSM.
