Problem with route leaking in the vxlan/evpn multisite fabric.
bgpripe
Hello everyone! I have a vxlan/evpn multisite fabric, two data centers 65502 - DC-2, 65503 - DC-3 and two vrfs: vrf_2 and vrf_3. I'm trying to route leaking between them  DC-2-BGW-1-1/1-2 (anycast bgw) and everything is correct on the routes in two vrfs, everything is correct on DC-3 on bgw in vrf_2, but there are not enough routes in vrf_3. Tell me where the error is.
config:
DC-2 bgw:
vrf context vrf_2
  vni 4000502
  rd auto
  address-family ipv4 unicast
    route-target both auto
    route-target both auto evpn
    route-target import 65502:5000502
    route-target import 65502:5000502 evpn
    route-target export 65502:5000502
    route-target export 65502:5000502 evpn
    import map import_vrf_2
    import vrf advertise-vpn
    export vrf allow-vpn
vrf context vrf_3
  vni 5000502
  rd auto
    route-target import 65502:4000502
    route-target import 65502:4000502 evpn
    route-target export 65502:4000502
    route-target export 65502:4000502 evpn
    import map import_vrf_1
dc-2-bgw-1-1# sh ip ro su vrf vrf_2
IP Route Table for VRF "vrf_2"
Total number of routes: 5391
Total number of paths:  5391
Unicast paths:
Best paths per protocol:      Backup paths per protocol:
  bgp-65502      : 5366         None
  broadcast      : 13
  direct         : 5
  local          : 5
  urib_internal  : 2
Number of routes per mask-length:
  /0 : 1       /8 : 2       /12: 1       /16: 3       /22: 3
  /23: 7       /24: 985     /26: 1148    /27: 1734    /28: 519
  /29: 520     /30: 7       /31: 10      /32: 451
dc-2-bgw-1-1# sh ip ro su vrf vrf_3
IP Route Table for VRF "vrf_3"
Total number of routes: 5387
Total number of paths:  5388
Unicast paths:
  bgp-65502      : 5369         None
  broadcast      : 5
  direct         : 2
  local          : 2
  urib_internal  : 10
  /29: 520     /30: 7       /31: 10      /32: 447
DC-3 bgw:
vrf context vrf_2
  vni 4000502
  rd auto
vrf context vrf_3
  vni 5000502
  rd auto
dc-3-bgw-1-1# sh ip ro su vrf vrf_2
Total number of routes: 5057
Total number of paths:  5058
Unicast paths:
  bgp-65503      : 5027         None
  broadcast      : 15
  direct         : 8
  local          : 8
  /23: 7       /24: 972     /26: 1124    /27: 1703    /28: 519
  /29: 520     /30: 7       /31: 10      /32: 185
dc-3-bgw-1-1# sh ip ro su vrf vrf_3
Total number of routes: 38
Total number of paths:  38
Unicast paths:
  bgp-65503      : 35           None
  broadcast      : 3
  /0 : 1       /8 : 1       /24: 17      /31: 4       /32: 15
What plat you have NXOS/XE/XR?
MHM
My Platform N9k - NXOS.
Show vrf <> detail <<- shar this for both vrf
MHM
Stefan Mihajlov
Level 3
Level 3
@bgpripe
Your config on DC-2 shows leaking between vrf_2 and vrf_3 using route-targets, but on DC-3 the BGWs only have the default both auto RTs. That’s why vrf_3 on DC-3 only learns a handful of routes — it isn’t importing the leaked RTs coming from DC-2.
For inter-VRF leaking to work across sites you need:
  • Matching import/export RTs on both VRFs in both sites.
  • The import vrf advertise-vpn and export vrf allow-vpn knobs set on the leaking side.
add the same explicit import/export route-targets for vrf_3 on DC-3 that you used on DC-2, otherwise those leaked routes will never be imported.
