QoS Problem
felipe.oliveira
Community Member
I migrated from 6500 hybrid (IOS+CatOS) to IOS-only. After that, the policy-map applied in some interfaces only work in one Catalyst. For example, if a put the interface vlan X active in one cat with the bandwidth limited to 3Mb, everything is ok. But if I change to the other Cat, the bandwidth is limited in 1.8Mb, and the settings are the same. Here is a sample of the conf:
mls qos aggregate-policer Ofici_FL3072 3144000 102000 102000 conform-action transmit exceed-action drop
class-map match-any class_oficinadaimagem_01
match access-group name qos_oficinadaimagem_01
policy-map banda_oficinadaimagem
class class_oficinadaimagem_01
police aggregate Ofici_FL3072
ip access-list extended qos_oficinadaimagem_01
permit ip any any
Is there a problem in hardware ?? Or an IOS bug ?? The same version is used on both.
Craig Norborg
Level 7
Level 7
What module type are the interfaces your applying these policies coming from? Are they the same exact model on both switches? If not, that could be the problem, different modules have different QoS characteristics on the 6500's...
To check the characteristics of the port(s), try doing a "show interface capabilities".
For more info on 6500 QoS, try checking out this page "Understanding Quality of Service on Catalyst 6000 Family Switches" at http://www.cisco.com/en/US/customer/tech/tk543/tk762/technologies_white_paper09186a00800b0828.shtml
I upgraded the IOS and it seems the problem is now gone. Thanks, anyway.
What version were you running and what version fixed this problem?
