Question about License for Nexus 1000v and time it supports not licensed ESXi's
Sami AlSawaftah
Hello
I have License for 12 cpu which are 3 ESXi's with 4 CPUs Each
so if I add another ESXi , will that be supported for 60 days
I am almost sure but wanted a confirmation
mwronkow
Hello Sami,
The 4th ESXi host will pull licenses from the Overdraft pool (sh license usage Nexus1000).  N1k ships with 16 overdraft licenses which can be used indefinitely as long as a real license is installed.  Although not required, we suggest purchasing a license to cover the host in the overdraft pool.
Also note the licensing model on N1k has recently changed.
Matthew
mwronkow
Hello Sami,
Matthew
Thanks Matthew
the other License is coming sooner , wanted just to check if it will be supported till then .
