session not establishing using dlsw
nflaherty
Community Member
I have two devices attached via token ring with a wan in the middle.
I see circuit established between devices at both ends but not to one device never goes into session.
show dlsw circ
Index local addr(lsap) remote addr(dsap) state uptime
352322278 0020.3542.0685(04) 0020.3539.79df(04) CONNECTED 2d01h
1946157249 0020.3542.0685(04) 0006.29f3.13d2(04) CKT_ESTABLISHED -
1174405860 0020.3542.0685(04) 0060.946e.1e96(04) CONNECTED 2d01h
4194304733 0020.3542.0685(04) 0060.94ff.5208(04) CONNECTED 2d01h
3808428416 0020.3542.0685(04) 0800.5aa4.5b23(04) CONNECTED 1w1d
1224736930 0020.3542.0685(04) 0006.29b0.c6e2(04) CONNECTED 13:54:27
1207960424 0020.3542.0685(04) 0020.35f1.fe7b(04) CONNECTED 2d01h
2868904131 0020.3542.0685(F0) 0004.ac94.7615(F0) CONNECTED 00:00:00
Total number of circuits connected: 7
a show llc command gives the following:
show llc
LLC2 Connections: total of 7 connections
TokenRing0/0 DTE: 0020.3542.0685 0020.3539.79df 04 04 state NORMAL
V(S)=71, V(R)=27, Last N(R)=71, Local window=7, Remote Window=127
akmax=3, n2=8,
xid-retry timer 0/0 ack timer 0/1000
p timer 0/1000 idle timer 7060/10000
rej timer 0/3200 busy timer 0/9600
adm timer 0/60000 llc1 timer 0/1000
akdelay timer 0/100 txQ count 0/200
RIF: 0690.0A01.0010
TokenRing0/0 DTE: 0020.3542.0685 0006.29f3.13d2 04 04 state ADM
In ADM state for 13412 msec, reason: LLC_LC_BOGUS ev: ZERO EVENT
V(S)=0, V(R)=0, Last N(R)=0, Local window=7, Remote Window=127
akmax=3, n2=8,
p timer 0/1000 idle timer 0/10000
RIF: 0690.0A01.0010
TokenRing0/0 DTE: 0020.3542.0685 0060.946e.1e96 04 04 state NORMAL
V(S)=117, V(R)=89, Last N(R)=117, Local window=7, Remote Window=127
akmax=3, n2=8,
p timer 0/1000 idle timer 4150/10000
RIF: 0690.0A01.0010
TokenRing0/0 DTE: 0020.3542.0685 0060.94ff.5208 04 04 state NORMAL
V(S)=92, V(R)=23, Last N(R)=92, Local window=7, Remote Window=127
akmax=3, n2=8,
p timer 0/1000 idle timer 6690/10000
RIF: 0690.0A01.0010
TokenRing0/0 DTE: 0020.3542.0685 0800.5aa4.5b23 04 04 state NORMAL
V(S)=64, V(R)=41, Last N(R)=64, Local window=7, Remote Window=127
akmax=3, n2=8,
p timer 0/1000 idle timer 6640/10000
RIF: 0690.0A01.0010
TokenRing0/0 DTE: 0020.3542.0685 0006.29b0.c6e2 04 04 state NORMAL
V(S)=13, V(R)=11, Last N(R)=13, Local window=7, Remote Window=127
akmax=3, n2=8,
p timer 0/1000 idle timer 1810/10000
RIF: 0690.0A01.0010
TokenRing0/0 DTE: 0020.3542.0685 0020.35f1.fe7b 04 04 state NORMAL
V(S)=90, V(R)=110, Last N(R)=90, Local window=7, Remote Window=127
akmax=3, n2=8,
p timer 0/1000 idle timer 4350/10000
RIF: 0690.0A01.0010
it looks to be xid negotiation fails on a parameter
any ideas
didyap
Level 11
Level 11
Take a look at the dlsw support page. you might find some doc that would help.
http://www.cisco.com/pcgi-bin/Support/browse/psp_view.pl?p=Technologies:DLSw
