Twinax cables with Catalyst Switches
Can someone tell me if Catalyst 9300 switches work with Twinax cables. Wanting to connect some Synology, HP, and Dell equipment to increase data transfer rates. Or if someone has a better idea for 10g connection between the devices.
2 Accepted Solutions
M02@rt37
Hello @00u18jg7x27DHjRMh5d7
Find bellow the references for C9300.
See media type 'DAC' and 10Gbps.
https://tmgmatrix.cisco.com/?npf=76
Best regards
Dustin Anderson
Yes, I use Twinax between cisco and devices if it's a short distance. Should be fine, but verify brand. I think I have used TrippLite
M02@rt37
Best regards
Dustin Anderson
Thanks for the information
You're welcome @00u18jg7x27DHjRMh5d7
Best regards
