VPC+ fabricpath - MAC address flapping between switch-id and VPC id
mmacdonald70
We have a fabricpath network configured.  For several days, we are seeing our logs filling up with errors from leaf nodes like:
%FWM-6-MAC_MOVE_NOTIFICATION:  Host aaaa.bbbb.cccc in vlan x is flapping between gpc1:502 and gpc1:50
- Most of aaaa.bbbb.cccc.dddd is the mac address of the SVI interface for each vlan gateway
- Vlan is the corresponding vlan for the SVI above
- gpc1:502 is the switch ID for the primary VPC peer
- gpc1:50 is the shared switch id
When I run 'show mac add' on each of the switches with the SVI, the primary shows sup-eth2 and the secondary shows 50.0.0
Show VPC shows VPC up with no errors.
I'm not sure where to look next.
Hello. Sorry for disturbing the old treat but did you resolved the issue?
We have the same issue on our Cisco nexus 7000. I have no idea where to find. All the interfaces affected with same thing.
Nexus1 %L2FM-4-L2FM_MAC_MOVE: Mac 0000.5e00.0198 in vlan 604 has moved from Eth4/15 to 111.0.14
Nexus1 %L2FM-4-L2FM_MAC_MOVE: Mac 0000.5e00.0199 in vlan 603 has moved from Eth4/15 to 111.0.14
Nexus1 %L2FM-4-L2FM_MAC_MOVE: Mac 0000.5e00.0196 in vlan 2371 has moved from Eth4/15 to 111.0.14
Nexus2 %L2FM-4-L2FM_MAC_MOVE: Mac 0000.5e00.0198 in vlan 604 has moved from 114.0.62 to Eth4/15
Nexus2 %L2FM-4-L2FM_MAC_MOVE: Mac 0000.5e00.0199 in vlan 603 has moved from 114.0.62 to Eth4/15
Nexus2 %L2FM-4-L2FM_MAC_MOVE: Mac 0000.5e00.0196 in vlan 2371 has moved from 114.0.62 to Eth4/15
