xthuijs
Introduction
This document decribes the ASR9000 netflow architecture.
It provides a basic configuration how to set up netflow and what the parameters are for scale and how netflow is implemented in the ASR9000/XR
Basic configuration for netflow
The basic configuration for netflow consists of an
Flow monitor map
An exporter map
and a sampler map.
The Flow monitor MAP pulls in the Exporter map
On the interface you want to enable netflow on, you pull in the monitor map and the sampler map.
flow monitor-map FM
record ipv4
exporter FE
cache permanent
cache entries 10000
! cache timeouts define how frequently we export what, max of 1M per LC
cache timeout active 2
cache timeout inactive 2
flow exporter-map FE
version v9
  options interface-table timeout 120
! these 2 define the exports of the sample map and interface table to theflow collector for sync'ing indexes
! to names etc.
  options sampler-table timeout 120
transport udp 1963
destination 12.24.39.1
source <interfacename>
sampler-map FS
random 1 out-of 1
interface GigabitEthernet0/0/0/20
description Test PW to Adtech G4
ipv4 address 16.1.2.1 255.255.255.0
flow ipv4 monitor FM sampler FS ingress
Scale parameters for netflow
Ø    Trident: 100kpps/LC (total, that is in+out combined)
       Typhoon: 200kpps/LC
Ø   1M records per LC  (default cache size is 64k)
Ø   50K Flows per sec export per LC
Ø   Sample intervals from 1:1 to 1:64k
Ø   Up to 8 exporters per map, vrf aware
Netflow support
ØIPv4 (unicast/multicast)
ØIPv6 (unicast/multicast)
ØMPLS (with or without IPv4/IPv6 fields)
Architecture
Netflow is not hardware accelerated in the ASR9000 or XR for that matter, but it is distributed.
What that means is that each linecard individually runs netflow by itself.
Resources are shared between the interfaces and NPU's on the linecard.
When you have 1 interface to one NPU on one linecard enabled for netflow, the full rate is available to that interface, which is 100k pps for trident and 200k for typhoon.
When you enable 2 interfaces on the same NPU on the same LC, then both interfaces share the 100k pps (trident) or 200k pps (typhoon)
When you enable 2 interfaces on 2 different NPU's, then both NPU's share the total rate of 100k/200k amongst them giving each NPU 50k or 100k depending on the LC type.
Packet flow for netflow
•Once they pass through the sampling policer, the ucode extracts data from the header fields and sends to LC CPU to construct a flow record.
•The LC CPU sends the flow record to netflow cache on the LC.
•The flow records remain in the LC cache untill they are aged due to either timer expiry or cache exhaustion.
•There are two timers running for flow aging, the active timer and the inactive timer.
Inside the LC CPU
Netflow Cache size, maintenance and memory
In IOS-XR platforms, it is the LC processor memory that holds the netflow cache.
NetFlow Cache is a Section of memory that stores flow entries before they are exported to external collector.
The ‘nfsvr’ process running on the linecard, manages the netflow cache.
Memory usage
The memory used can be monitored via this command:
           show flow monitor FM cache internal location 0/0/CPU0
          Memory used:                             8127060
Total memory used can be verified by checking the process memory util of "NFSVR"
show processes memory location 0/0/CPU0 | inc nfsvr
257       139264     65536     73728   12812288 nfsvr
Sample usage
The memory used with the cache size of default 64k entries for ipv4 & MPLS is about 8MB & for ipv6 is about 11MB.
The memory used with the cache size of maximum 1M entries for ipv4 & MPLS is about 116 MB & for ipv6 is about 150MB.
The memory used with cache size of maximum 1M entries (default is 65535) is about 116 MB per ipv4 flow monitor .
If ‘n’ ipv4 flow monitors are used all with maximum 1M entries, the memory used would be n x 116 MB.
Cache Size
The default size of the netflow cache is 64k entries. The maximum configurable size of the netflow cache is 1M entries.
Configuration to set the cache entries to ten thousand looks as follows:
flow monitor-map FM
cache entries 10000
Aging
95% of configured cache size is the high watermark threshold. Once this threshold is reached, certain flows (longest idle ones etc) are aggressively
timed out. XR 4.1.1 attempts to expire 15% of the flows.
The show flow monitor FM cache internal location 0/0/cpu0    command will give you the data on that:
Cache summary for Flow Monitor :
Cache size:                         65535
Current entries:                       17
High Watermark:                     62258
NETFLOW-6-INFO_CACHE_SIZE_EXCEEDED
this syslog message means that we wanted to add more entries to the cache than what it could hold. There are a few different reasons and remediations for it:
- the cache size is too small, and by enlarging it we can hold more entries
- the inactive timeouts are too long, that is we hold entries too long in the cache not getting aged fast enough
- we have the right size cache, and we do export them adequately, but we are not getting the records out fast enough due to volume, in that case we can tune the rate limit of cache expiration entries via:
flow monitor <name> cache timeout rate-limit <time>
Permanent cache
The permanent cache is very different from a normal cache and will be useful for accounting or security monitoring. The permanent cache will be a fixed size chosen by the user. After the permanent cache is full all new flows will be dropped but all flows in the cache will be continuously updated over time (i.e similar to interface counters).
Note that the permanent cache uses a different template when it comes to the bytes and packets.
When using this perm cache, we do not report fields 1 and 2, but instead use 85 and 86.
Fields 1 and 2 are “deltas” 85 and 86 are "running counters".
In your collector you need to "teach" it that 1 and 85, 2 and 86 are equivalent.
Characteristics
Number of flows : Total number of unique flows going through the interface in a given time period.
Cache timeout values : In general, the longer the timers, the larger the needed cache size. Short timers dictate that most records will be removed due to aging.
Average flow duration : The longer the average flow duration, the longer the timers that are needed, and thus the larger the cache.
Sampling Rate : Lower the sampling rate (i.e. lower the X, for 1:X), more flows would be populated in the cache and hence larger cache size is needed.
Which packets are netflowed?
All packets subject to sampling, regardless or whethe they are forwarded or not are subject to netflow.
This includes packets dropped by ACL or QOS policing for instance!
A drop reason is reported to NF..
* ACL deny
* unroutable
* policer drop
* WRED drop
* Bad IP header checksum
* TTL exceeded
* Bad total length
* uRPF drop
Example
IPV4SrcAddr      IPV4DstAddr      L4SrcPort  L4DestPort IPV4Prot IPV4TOS InputInterface  ForwardStatus        ByteCount    PacketCount  Dir
17.1.1.2         99.99.99.99      3357       3357       udp      0     Gi0/1/0/39      DropACLDeny          415396224    8654088      Ing
Sampling
As described in the architecture section, the total sampling capability depends on the number of interfaces having netflow enabled.
It shaped up to be something like this table:
# of NPs Enabled for Netflow
Policing Rate Per Trident NP (Unidirectional)
Policing Rate Per Typhoon NP   (Unidirectional)
100kpps
200kpps
50kpps
100kpps
33kpps
66kpps
25kpps
50kpps
Punt Policing of netflow packets
All packets that exceed this rate are dropped by the punt policer.
You can verify that by the controllers np counters command.
show controllers np counters all
                Node: 0/0/CPU0:
Show global stats counters for NP0, revision v2
Read 67 non-zero NP counters:
Offset  Counter                                         FrameValue   Rate (pps)
934  PUNT_NETFLOW                                     18089731973        6247
935  PUNT_NETFLOW_EXCD                                       6245           0
The _EXCD depicts that the police rate had been exceeded.
This means that you likely have to increase your sampling interval.
Monitoring netflow
sh flow monitor FM cache format table include layer4 tcp-flags ipv4 sour dest prot tos count pack byte location 0/0/CPU0
Mon Apr 19 09:31:19.589 EDT
Cache summary for Flow Monitor FM:
Cache size:                          10000
Current entries:                         1
High Watermark:                       9500
Flows added:                             1
Flows not added:                         0
Ager Polls:                            580
  - Active timeout                       0
  - Inactive timeout                     0
  - TCP FIN flag                         0
  - Watermark aged                       0
  - Emergency aged                       0
  - Counter wrap aged                    0
  - Total                                0
Periodic export:
  - Counter wrap                         0
  - TCP FIN flag                         0
Flows exported                           0
IPV4SrcAddr      IPV4DstAddr      IPV4Prot IPV4TOS  L4TCPFlags   ByteCount    PacketCount
16.1.2.2         16.1.1.2         tcp      0        S|           4282560      71     376
Matching entries:                        1
The exporter (MAP)
Export occurs when data in the cache is removed which can occur in one of three ways.
  • Inactive timer expiry : The cache entry expires due to not matching an incoming packet for a specified amount of time. Default value is 15 seconds.
  • Active timer expiry : The cache entry, though still matching incoming packets, has been in the cache so long that it exceeds active timer. Default value is 30 minutes
  • Cache Exhaustion : The cache becomes full, so some of the oldest entries are purged to make room for new entries.
The netflow exporter can be in a VRF, but can not be out of the Mgmt Interface.
Here’s why. The netflow runs off of the line card (LC interfaces and NP) and there is, by default, no forwarding between the LCs and the management Ethernet.
This because the MGMT ether is designated out of band by LPTS (local packet
transport services). More detail in the ASR9000 Local packet transport services
document here on support forums).
Netflow records can be exported to any destination that may or may not be local to the LC where netflow is running. For example, LC in slot 1 & 2 are running netflow & the exporter may be connected to an interface reachble via LC in slot 3.
A total of 8 exporters per MAP is allowed.
Troubleshooting Netflow
RP/0/RSP0/CPU0:A9K-TOP#show flow exporter FE location 0/0/CPU0
Tue Nov  16 11:23:41.437 EST
Flow Exporter: FE
Flow Exporter memory usage:  3280812
Used by flow monitors: FM
Status: Disabled  ><<<<<<<><><><><><>>>>>>>>>><<<<<<<<<
Transport   UDP
Destination 3.0.0.38         (1963)
Source      0.0.0.0         (12162) <<<<<<< PROBLEM!!
Flows  exported:                                   0 (0 bytes)
Flows  dropped:                                    0 (0 bytes)
Exporter fields
Export protocol only supported is Netflow v9 over UDP.
Flow record key fields
  • IPv4 source & destination addresses
  • IPv4 protocol & TOS byte
  • Transport source & destination ports
  • Input interface
  • Direction
  • Forwarding status
  • BGP next-hop
Flow record non-key fields
  • TCP flags
  • IPv4 source & destination prefix mask length
  • Source & destination BGP AS #
  • IPv4 address of BGP next hop
  • Packet & byte counters
  • First & last packet timestamps
  • Output interface
Not supported features
Ø Export format v5, v8
Ø DBNA
Ø FEC for all types of labels
Ø Netflow activation on per MQC class basis
Ø NetFlow for L2 switched traffic
Ø Cisco netflow mib is not supported.
Netflow cache size considerations
Cache size too small : If the number of flows is significantly larger than the cache, the router will perpetually age records and consume more CPU time and bandwidth to export.
Cache size too large : It can waste memory if the number of flows is too less compared to cache size.
Trident ASR9K LC, even with max cache size of 1M, the memory consumption increases by 2.5% per ipv4 FM. (116 MB from 4GB)
Typhoon ASR9K LC, even with max cache size of 1M, the memory consumption increases by 1.25% per ipv4 FM. (116 MB from 8GB)
Recent enhancements
A few nice enhancements have been added to netflow recently:
- ability to tune the rate-limiting for cache expiration (see above for more detail)
- bgp attribute download for full AS-PATH and communities (need to configure bgp attribute download)
- visibility on the phyiscal member used for this record on a bundle or mpls TE tunnel (needs outphyint config on the monitor map)
- ability to see which interfaces are using this flow monitor map. this is handy in case you need to modify the netflow config and have a list of all intfs using the map.
- and yes :) we are working on an inline modification too :)
Show commands
show flow exporter-map ..
show flow monitor-map ..
show sampler-map ..
show processes memory location <0/0/CPU0> | inc nfsvr
show flow monitor .. cache internal location <0/0/CPU0>
show flow exporter .. location <0/1/CPU0>
show flow platform producer statistics location <0/0/CPU0>
show flow platform nfea policer np <np_num> loc <node-id>
show controller np ports all location <0/Y/CPU0>
show controller np count np<number> loc <0/Y/CPU0>
xthuijs
hi garry, it doesnt look like it made it in xr60/61 will check what the plan of record is for the flexible netflow. I think it lost some traction because of the telemetry application that seems to get a lot more traction.
this is currently in development, some glitches to be gleaned out, once iti s a bit more solidified I'll make a write up on that also, as it seems very interesting.
cheers!
xander
Umpri
Hi Xander! how are you!.. I d´appreciate if you could give some help
In next month we are going to intall 26 MOD-200-SE with 2x100G MPA. We will need to configured there as we have today,
flow mpls monitor
regarding this, today we have it in the uplinks interfaces
RP/0/RSP0/CPU0:BEL1MB#sho run int tenGigE 0/5/0/0
flow mpls monitor MPLS_UPLINK sampler FNF_SAMPLER_MAP ingress
where...
flow monitor-map MPLS_UPLINK
record mpls ipv4-ipv6-fields
exporter FNF_EXPORT_MAP
exporter EXPORT_MAP_Deepfield_1
cache entries 70000
cache timeout active 50
cache timeout rate-limit 500000
sampler-map FNF_SAMPLER_MAP
random 1 out-of 10000
Due to the newones are tomahawk technology , I need to know if Cisco will go on recommending a sampling of 1:10000 or  it is possible forward to configure 1:1000. And in that case which are the recommendatios or suggestion for cache parameters.
Best refards!
Cheers!
Javier
xthuijs
hi javier! :) the TH cards like typhoon have a punt policer for netflow of 200kpps per LC.
since the mod 200 has one NPU, that 200kpps is available for that single NPU and aggregated over all the interfaces that the MOD runs.
So both 100G interfaces share that 200kpps.
Based on simple math: at 200kpps with 1500 byte packets we are at 2.2Gbps.
so with a sampling rate of 1 out of 1000 *and* a packet size of 1500 we could sustain 200G and that sampling rate.
Likely your av pak size is smaller than 1500, so we have to be higher then 1000.
sampling 1:10,000 generally gives you enough insight already. you can go lower, but if the pak size is too small, we may see more then 200k pps requested to be punted that lpts will prevent.
so focus on the NFLOW_EXCEED counter in lpts to see if you are hitting that max punt rate in case you go lower then 1:10,000.
cheers!!
xander
Umpri
Hey Xander!! thank you!! you are faster than a hundredgig!
Cheers
javier
Adam Vitkovsky
Level 3
Level 3
Hi Xander,
Agree that 1:10,000 is de facto standard, but with regards to the LPTS –can the netflow punt rate be lifted via configuration please?
Thank you
adam
netconsultings.com
::carrier-class solutions for the telecommunications industry::
xthuijs
ah yeah most policers are configurable, the netflow policer (along with some others) are hard coded. the netflow policer is a software setting that can't be overridden. I have a request open for that  as I feel we can go higher, but no one has made it a serious request, so that is shelved. (subject to dev and test)xander
Adam Vitkovsky
Level 3
Level 3
I see so this one is fixed, well yeah I don’t see a compelling reason why this policer should be configurable either, netflow is not a port mirror, so maybe preventing engineers from shooting themselves in the foot by enforcing the rate limit is the right thing.
adam
netconsultings.com
xthuijs
not yet integrated in any code, but the request is peding adam :).
true netflow is not port mirror, but some folks like lower more aggressive sampling rates to get better visibility. TH and its lc cpu can do much better then 200kpps/LC so technically it should be possible, one and other depending on the available pps on the npu and business of the lc cpu. that is a large qualification effort hence the reluctance going larger.
cheers!
xander
Adam Vitkovsky
Level 3
Level 3
Intel IVY Bridge EN 6 cores @ ~2GHz with 3x 8Gig DIMMs, I bet it could do more than 200kpps :)
But I appreciate that actually copying the packets from the NPU, while not crippling it’s performance too much, has to be the hardest part indeed.
Thank you
adam
Umpri
Hey! hi Xander how are you.... Could I add another question, we are noticing in syslog we have %PKT_INFRA-PQMON-6-QUEUE_DROP and the TAC recommended us to change the Netflix sampling ratio to 1:10000 because the queue XIPC was doing taildrop (maybe because of netflow).. so my question is, if it is possible to change the size of the XIPC queue, or better ignore this alarm message in spite of having a rate of 1:1000.
Best regards!
Javier
PD: TAC said:
Basically, this message "%PKT_INFRA-PQMON-6-QUEUE_DROP" means that sampling is too low and it is depleting XIPC due to the big amount of packets exported to NetFlow.
Now, speaking of the possible affectation/degradation created from these logs:
-No traffic will be affected AT ALL. Packet forwarding will forwarded normally as NetFlow is an independent operation from packet forwarding via CEF or CPU.
-The drops that we’re seeing simultaneously with these messages are on this particular queue for NetFlow export. NetFlow won’t be sampling 1 packet every 1000 as it will be dropping some as it doesn’t have enough space on the buffer. Basically, the only problem with this log is that we won’t be having a 1:1000 sampling.
For the next steps and to alleviate this problem, our recommendation is to lower the Sampling from 1:1000 to a larger value. On command reference, you can see the recommendation is a value of 1:10000.
ubaidjamer
Community Member
Hello
hope you are doing good
Need Help
I am not sure if you will be seeing this but we are running into a strange problem on ASR9k we enabled netflow all the config seems proper exporter shows the cache is properly updated as no of packets processed increases but some how the netflow collector (maintained by tools team) seems not receivng the flows, the team says may be the router is not sending it after all , they claim this as the firewall in between dont see any netflow  traffic (on a specific port) comming from my router towards netflow collector server, however ping and trace goes from router source to the netflow collector and are logged in the firewall , once we remove the config and add back firewall team says they see that some traffic passed and then it stopped after a while ..
we are using loop back in global table and the netflow collector route is also in global table but we have enabled the ingress and egress on 0/5/0/X which is in VRF INTERNET ..
any ideas what caused this netflow data not to be sent to collector even though the cache is showing properly and stats has no packet drops
smailmilak
Level 4
Level 4
if the "Flows exported:" part is increasing then it should be going to the destination, i.e. netflow collector.
Does the FW support packet capture? If it's an ASA then you can capture the traffic with command "capture" and the show capture for destination and port udp 5000.
If you see the netflow traffic on the FW then do the capture on the NMS. It's probably a linux distro and it's easy to accomplish that.
xthuijs
also make sure that the export dest is reachable with the source configured from the a9k and ensure that it is not found via the mgmt interface.
look at show flow exporter-map stats to see what is going on from an export perspective also.
xander
ubaidjamer
Community Member
Thank you both
Finally a relief we have been bothered by this many a times and found after a bit of luck that the ASA will not show the logs of the live netflow traffic it only shows once when the session is established with the flow server/collector and then there is nothing even though the data is received on the server .. I am still not sure why the server stops receiving abruptly while the router sends the data (may be server capacity issue only server guys can figure out) but it became clear that router has no issues what so ever and if this sort of issue happens again it will be on server/tools team... Cheers..
Evan Roggenkamp
Hello I am wondering how to use this with the following configuration:
interface Bundle-Ether12.3481
description --- TRANSPORT ---
ipv4 point-to-point
ipv4 unnumbered Loopback3401
arp timeout 300
proxy-arp
lldp
transmit disable
load-interval 30
flow ipv4 monitor FNM-IPV4 sampler ONE_PER_HUNDRED ingress
flow ipv4 monitor FNM-IPV4 sampler ONE_PER_HUNDRED egress
encapsulation dot1q 3481
Will this configuration work on this interface?
